Lotherton Diagnostics Results
Find out about meetings and cruises in here. Make the best use of your Z!
Whilst we were at Lotherton Hall last weekend, I ran diagnostics on a couple of cars. One was a Z3 roadster 2.0, belonging to TROOPER47 (aka Roger) and was my first opportunity to plug into a car with both OBDII and round 20-pin connectors - nett result of which was that the ONLY module we could talk to via the under-dash OBDII connector was the engine, this reinforcing the theory that this was only added to assist with emissions testing and not for general diagnostics.
What follows are the screenshots and translated text from his car. Any theories as to what some of the codes mean in practice would be appreciated.
ENGINE
Code: Select all
63  Ansteuerung Lambdasondenheizung nach KAT Bank 2
    Oxygen sensor heater control by KAT bank 2
216 Signal Lambdasonde Nach-Kat Bank 2 kein Signal
    Signal post-catalyst oxygen sensor bank 2 no signal
39  Plausibiliaet Signal Bremslichtschalter / Bremslichttestschalter
    Plausibility signal brake light switch / brake light test switch
2   Ansteuerung Zuendung Zylinder 4
    Ignition Control Cylinder 4
242 Verbrennungsaussetzer Zylinder 5
    Misfire Cylinder 5
243 Verbrennungsaussetzer Zylinder 6
    Misfire Cylinder 6
240 Verbrennungsaussetzer Zylinder 3
    Misfire Cylinder 3
AIRBAG
Code: Select all
3   Zuendkreis ZK2 -> Gurtstrammer Beifahrer
    Ignition circuit ZK2 -> Belt-tensioner passenger
2   Zuendkreis ZK1 -> Gurtstrammer Fahrer
    Ignition circuit ZK1 -> Belt-tensioner driver
ASC/ABS
Code: Select all
49  Drehzahlfuehler hinten links Triggersignal
    Speed sensor rear left trigger signal
68  Drehzahlfuehler hinten rechts Anfahrerkennung
    Speed sensor rear right (acceleration starting/detecting starting)
65  Drehzahlfuehler hinten rechts Triggersignal
    Speed sensor rear right trigger signal
ALARM
Code: Select all
19  WC-Toleranz erhoeht bei Schluessel Nummer 1
    WC-Tolerance incremented by key number 1
15  Power-On-Reset
83  WC-Toleranz erhoeht bei Schluessel Nummer 4
    WC-Tolerance incremented by key number 4
INSTRUMENTS
Code: Select all
245 keine CAN ID ASC1
    No CAN ID ASC1
THERMAL OIL LEVEL SENSOR
Code: Select all
2   Drehzahlsignal
    Speed signal
Re: Lotherton Diagnostics Results
Post by pingu »
Engine
216 - suspect open circuit in wiring or damaged llambda sensor
63 - probably linked to above
39 - caused by using brake with throttle pedal pressed (cured by clearing code)
2 - ign module loose, duff spark plug, knackered module, loose earth lead to module, the list goes on...
242, 243, 240 - spark plugs, ign modules, fuel mixture, injectors, etc.
Airbag
3 - tensioner has been fired, or open circuit.
2 - as above.
ASC/ABS
49, 65 - dirty sensor
68 - dirty sensor
Alarm
??? - if alarm works, just clear the codes
Instruments
I think this means the INPA can't "talk" to the instrument cluster
Thermal Oil Level Sensor
2 - ??? - just clear the code
Error Memory Codes
Use a translator, the codes tell you what the revs (and temperature) were when the engine problems above happened.
If the car runs OK and there are no lights on the dash, I'd take a copy (as you have), clear the codes, run for a few hundred miles or until problems occur, then recheck the codes.
Post by Del »
Looking at the error codes for the engine/fuel management (and the frequency with which they occur) I would guess there is a problem with the post-cat lambda sensor - there are 199 occurrencies of it not reporting the correct signal (error 216) and 1 occurrence (61) of it failing to heat-up properly.
Error code (2) specifically relates to a problem with the ignition coil on cylinder 4 - (eight occurrencies). It may be in the early stages of starting to breakdown.
The non-specific mis-fires on cylinders 3,5 & 6 have each only occurred once and my guess is that they are possibly related to the post-cat lambda error (61).
Few more snippets of information from me:
I cleared the airbag codes and the driver's tensioner code came back immediately. The airbag light was on faintly, indicating a blown or removed airbag bulb. Roger was going to investigate what has been done with the cluster - we have previously seen the hole filled with paper to block out the secondary light - need to see whether the bulb is present and if it is blown.
The ABS light was on, but cleared after I cleared the error codes. I did lose connectivity with the ABS/ASC module at one point, which came back after turning the ignition off and on again - I think this my be related to the "No CAN ID ASC1" error. The other codes relate to wheel sensors and a good clean might cure these, if not, I'd replace the sensors.
I with you on the engine codes. Lambda sensor and possibly a coil pack.
