Right Since installing my new speakers/amp I installed the aftermarket sony headunit which the previous owner had fitted - this works fine/powers down correctly etc..
My new Pioneer headunit turned up today, so i used the existing converter from the sony headunit (to convert from the BMW block connector). I plugged this into the pioneers loom and the headunit powers up fine, all functions work correctly etc..
Now the strange bit, the headunit doesnt respond at all when you turn the ignition off and remove the key - it just stays on!. I removed the faceplate which seems to make it turn off but the mileage indicator on the dash stays lit! The car also wont respond to the remote central locking and will only allow me to lock the car via key!!!
Any ideas what this could be? I cant see why the dash is linked to the HU's power at all?
New Headunit - Not powering off along with other power issue
Check the permanant positive and switched positive some head units require these to be switched around. It maybe this which is causing the switched positive in the car to be still powered up through the head unit. Head unit wiring usually allows for the positive wires to be switched over quite easily so shouldn't be too difficult to at try and see if this is the problem.
Aceman
Arctic Silver '98 Z3M
Previously;
Bright RED '99 Z3 2.8
Previously;
Thanks for all the replies, you guys were spot on! the seller had decided to connect the red & yellow cables altogether!! once i'd split them and run red to red & yellow to yellow all is working normally!
