I have done some searching, but from the results there is nothing that matches my problem. My passenger side footwell speaker works fine, as do the door tweeters & rear speakers. However, the drivers side footwell speaker refuses to issue a note. I have removed the speaker as I thought that it could be blown, but I see no outward sign of that. I then thought perhaps the speaker was being earthed by the car body, but there was no sound when laying it on the carpet. I also removed the passenger side speaker to see if there were any wiring issues, but saw none.
So does anyone know if this is a simple issue? Can I replace the speaker temporarily with another (it has the simple spade connectors) to see if the speaker is at fault? Or should I just replace both with a plug 'n' play type (e.g. Rainbows IQ range)?
I do intend to, at some point, replace the stock audio system, but for now I'm content with the stock system (provided I can get the speaker to work!).
Thanks! /vince ..
