Windows Xp install probelms....
Hello,
I am trying to install windows XP (mmmmm backup) to a laptop..
Tried all the usual ways, self start, start..run etc etc
but I get the message when trying a self boot CDBOOT MEMORY ERROR (or similar?)
I have exactly the same spec computer with XP on it working fine, I also trued the diss in another machine and it worke fine...
Im I doing something obvious wrong??
Scott
Scott
Scott is the backup disc an exact copy of the original? sometimes if a disc has a title added or is written as a data disc, it does not work. To get my xp pro on I first have to load Xp home, if I want to format the drive, (which is an exact copy) then copy the pro disc to the hard drive and load from there. long winded but it works this way, whereas if i put the pro disc in the cd drive and try to load it from there it always comes up with an error.
help
Cheers,
As far as I know its an exact copy...
I have installed in on a desktop pc no problem, but on the laptop its having none of it, and its exactly the same machine as the one I use, memory, processor everything...?? very odd
cheers
scott
cheers
scott
Just as a point of reference. SP2 works just fine. I've rolled out 20 + PC's with it loaded and its not an issue. Seems to be a problem with machines that have obscure software packages on them. The biggest consideration is integrating them with firewalls and AV software, it definately doesnt like two firewall packages running for starters!
The laptops I have, came with Manufacturers Installation CD Roms, which have the additional drivers for the hardware.
I haven't tried to install from a straight forward Windows Xp disk - could your problem be lack of drivers from manufactures disk?
Re SP2 I have installed it on 4 machines with little to no problem - only thing needed was to update some applications
Laptops and the lack of generic drivers with WHL compatiability has always been a prob for XP and even 2K to update. The best course of action I've seen with SP2 is to ensure that all the SP's have been loaded prior to running SP2. Its easy if you have DSL of some description, though the majority of people dont have that luxury. One particular issue that people often negate is that the BIOS is woefully out of date on most peoples platforms, though updating them is really for the domain of competant people. Take for example a dell d600 i use, supplied with version 6 of the bios, current version 14 and its less than a year old. Its always a good idea to read the mainboard manufacturers website on the bios just to see what tweaks they've done. It sometimes gets most people out of a lot of difficulty.
- tetchmeister
- Z Register member
We have rolled out SP2 on 4000 PC's and Laptops globally, and have only had 3 problems.Robin wrote:mroadply I can only comment on my son who had problems with SP2 & also a profesional IT & PC expert who says to avoid SP2. I think you have been lucky & that the conflicts you mention are common enough for most people to need to be wary.
