Wanted: front left shock absorber
I need a front left shock absorber (passenger side) for a 1998 1.9
RealOEM part number 31316753257 I think.
As cheap as possible please, newbie
My Zeemer: 1998 BMW Z3 1.9 Atlanta Blue
Re: Wanted: front left shock absorber
Don't buy second hand dampers.
Or brakes..
Or steering parts..
You know why.
Or brakes..
Or steering parts..
You know why.
i just bought a front left and right from ebay (but it is straight from eurocarparts) and they were £30 for one and £50 for the other.
always replace in pairs or it could prove to be a big mistake.
Always buy shocks in pairs.
yeah spotted these: http://www.ebay.co.uk/itm/290714180119 & http://www.ebay.co.uk/itm/110881657225
what are they like to replace?
also spotted i have a leak at the bottom corners of my rear screen, there is no 'beading' on the screen as i have seen on others? coud this be a cheap aftermarket screen and need replacing?
many thanks!
many thanks!
when changing them will i need to change any other parts??
Easily fixed - see attached link. You simply need to clean underneath, squirt in your glue and ease the canvas back under the rubber strip with a credit card. It's glued down from new by BMW but the glue breaks down over the years. Mine was pouring in the two bottom corners when I got my car two years ago - been as dry as a bone since.dw1985 wrote:also spotted i have a leak at the bottom corners of my rear screen
http://www.ebay.co.uk/itm/Bostik-Soft-P ... 3a8292228d
that's the one I bought. I also used anschler rear shocks and they seem very well built. according to eurocarparts website they are built to OEM spec.dw1985 wrote:yeah spotted these: http://www.ebay.co.uk/itm/290714180119 & http://www.ebay.co.uk/itm/110881657225
many thanks!
they are very easy to replace but you will need a jack, axle stands, socket set / spanners and spring compressors and I would be tempted to replace the top mounts to be on the safe side.
there is a video on youtube showing how to replace them.
if you want any more info, pm me.
hope it helps.
there is no rubber strip / bead?Del wrote:Easily fixed - see attached link. You simply need to clean underneath, squirt in your glue and ease the canvas back under the rubber strip with a credit card. It's glued down from new by BMW but the glue breaks down over the years. Mine was pouring in the two bottom corners when I got my car two years ago - been as dry as a bone since.dw1985 wrote:also spotted i have a leak at the bottom corners of my rear screen
Second pic in this thread shows the beading very well: http://www.zroadster.net/forum/viewtopic.php?p=69229dw1985 wrote:there is no rubber strip / bead?
i see that, but mine has none...?Robert T wrote:Second pic in this thread shows the beading very well: http://www.zroadster.net/forum/viewtopic.php?p=69229dw1985 wrote:there is no rubber strip / bead?
The do you perhaps have a replacement roof with a sewn-in rear window? You should be able to see a zip on the inside if it is an original.dw1985 wrote:i see that, but mine has none...?
