As title £25 delieverd to mainland UK
For sale - square (pre-facelift) Z3 OBC clock trip computer
Re: For sale - square (pre-facelift) Z3 OBC clock trip compu
will it fit my z3 y reg? if so I will have it
Facelift was april 1999 (T reg) - yours will be later than this (build date will be on one of your front turrets under the bonnet.
T-reg started 1st March 1999, so not all T-regs will be facelifts (mine isn't). Build date is more accurate, though simply looking at the rear of the car is easiest - curvy arse = facelift.
It will not fit you car, Peter. Hole in your dash is the wrong shape and it has a different connector.
Aye, sorry, was saying they changed on the T reg, you're right not all of the T reg's though. One thing that always got me about the change was that mine had a throttle cable for the pedal but for the cruise control it was fly by wire... I would have thought it was all either cable or all fly by wireRobert T wrote:T-reg started 1st March 1999, so not all T-regs will be facelifts (mine isn't). Build date is more accurate, though simply looking at the rear of the car is easiest - curvy arse = facelift.
Never mind though it might
Peter2b
Peter2b
My friendly mechanic tells me when car makers change specs they use up existing parts off the shelf until they get to the new bits so a car built 2 mins after another may have different spec!
