keep getting logged out?
Any site announcements will be made here. Also the place to make suggestions to help improve this site. Also use this forum for reporting suspected errors or for asking 'how to' questions.
Post by swamper »
any ideas how to stop it happening?
iv deleted all the cookies already
thanks
Ragtop
Re: keep getting logged out?
Post by Ragtop »
Swamper when the site went down for a while in December some of us altered the host file to get access, did you alter your host file ?
I was getting logged out since the upgrade, i.e having to log in every visit to the site. I altered the host file today and everything works ok now.
When you log in now what is in your browser is it http://www.zroadster.net or 62.233.106.208 ?
Post by swamper »
its 62.233.106.208
Ragtop
Post by Ragtop »
Thats your problem it should be http://www.zroadster.net
Can you PM Robert T and he will be able to explain how to alter your host file. I'm not an IT person and don't want to mess your computer up. I did it with some help from Mrs Ragtop after a lot of searching for the host file but I'm no expert.
Post by swamper »
cheers ragtop...i think iv just changed in....iv deleted the old book mark and added the new one seems to have done the trick...thanks for your help :wink:
Ragtop
Post by Ragtop »
I tried that earlier today and it didn't work for me. Fingers crossed it works ok for you.
Post by swamper »
yep its still working.. :D
I think swamper bookmarked the page using the ip address and so kept going back to that.
If you type in zroadster.net and still get the old site with it's message page, then it is likely your hosts file still has the entry in it that we used before Christmas. Let me know and I'll tell you how to remove it.
billz
  Z4 roadster 3.0si
Post by billz »
Would be handy to have the adjustment so we can all view it and make adjustments as needed. I altered mine when .net was down but to be honest have forgot how to switch it back. Suppose if i find the thread then i will be able to do it.
bill
Z3 3.0 Sports Sold
Assuming you are on Windows Vista or Windows 7, then bring up the Start menu and click or hover over All Programs at the bottom - the menu changes to show more programs - scroll until you see the Accessories folder and click on it to expand it - Notepad should be amongst the entries - now right-click on the Notepad entry to bring up a menu (you would normally left-click to run it) - the second item should be Run as Administrator - select this.
The screen will now dim and a single bright window will appear asking for permission to run the program (it says something like Do you want to allow the following program to make changes to your computer?). Say Yes.
Notepad now starts with a blank window. Go to the File menu and select Open... Navigate to C:\Windows\system32\drivers\etc and select hosts. You will probably need to change Text Documents (*.txt) to All Files (*.*) to see it.
When the file opens, look for the line that says:
Code: Select all
213.188.134.178 www.zroadster.net
and either delete the entire line, or insert a # character at the start of the line to give:
Code: Select all
#213.188.134.178 www.zroadster.net
Linux users just need to do something along the lines of:
sudo nano /etc/hosts
Edit and save the file.
billz
  Z4 roadster 3.0si
Post by billz »
Thanks Robert.
bill
Z3 3.0 Sports Sold
Post by swamper »
wont let me save the file... im running it as admin.
message "cannot create the Cwindows system32 drivers ect hosts file
make sure the path file and name are correct"
more help please... :D
Boysie
Post by Boysie »
swamper wrote:wont let me save the file... im running it as admin.
Stick to what your good at, paving, erecting offices and bricking walls :lol:
Ray
Post by swamper »
have to agree there ray.... :lol:
Swamper, did you copy and paste that? In which case you have typed "ect" rather than "etc".
When you open the file is should have some content and not just be blank. When you save it, you should not have to re-enter the filename. Make sure you use Save rather than Save As, or just click X to close the window and answer Yes when it asks you if you want to save the file.
Post by swamper »
it has has text you described Robert and i did type it sorry for the mistake
if i try to make changes to it it wont let me save it ...iv tried as you have said both using # and delete the line being run as admin..but no luck
copy
# Copyright (c) 1993-2006 Microsoft Corp.
# This is a sample HOSTS file used by Microsoft TCP/IP for Windows.
# This file contains the mappings of IP addresses to host names. Each
# entry should be kept on an individual line. The IP address should
# be placed in the first column followed by the corresponding host name.
# The IP address and the host name should be separated by at least one
# space.
# Additionally, comments (such as these) may be inserted on individual
# lines or following the machine name denoted by a '#' symbol.
# For example:
# 102.54.94.97 rhino.acme.com # source server
# 38.25.63.10 x.acme.com # x client host
127.0.0.1 localhost
::1 localhost
# Start of entries inserted by Spybot - Search & Destroy
127.0.0.1 www.007guard.com
127.0.0.1 007guard.com
127.0.0.1 008i.com
What version of Windows are you on, Swamper? It sounds very much like you don't have sufficient rights to save the file.
Post by swamper »
vista........and this is was someones laptop before i had it...you probably on the right lines there...but i dont know how to change it :roll:
i'll stick to fixing stuff i know about :lol:
