Rear Camber Kit It's The Future
topfuelking
  Z3 roadster 2.8 supe
Post by topfuelking »
Hi all
just got a rear camber kit from the usa only two days by post
and 3 hours to fit and all i can say is wow
the car is so much better more grip low tyre noise less twitchy
it's got to be done
http://cgi.ebay.com/ebaymotors/KMAC-REA ... dZViewItem
http://www.bavauto.com/Assets/inst_pages/ins032.pdf
THANKS MARC
stu
Post by stu »
pdf link no worky for me Marc
cleomantra
Post by cleomantra »
Hi TFK do you have any pics I would like to see what it looks like before I go and order a set
Cheers Berti
exdos
  M coupe S54
Post by exdos »
I bought a set of these things (from AKG in the US) about 12 months ago, but sent them back, because when I properly examined them, I couldn't see how these things will maintain their settings over the longer term, bearing in mind the forces involved.
Instead, I fitted the Ireland Engineering adjustable caster and camber brackets to the subframe as found here:
http://store.nexternal.com/shared/Store ... oducts.asp
IMO this is a far better solution, although a much more difficult installation, because the eccentric washer heads and washers lock into the bolt and the bolt needs to be rotated for the camber/caster position to be adjusted. Therefore, any change is impossible unless you do this with a spanner. I've been runnning with almost zero rear camber and zero toe for the past 12 months and the photo below shows one of my old tyres from the O/S, a Falken 451 size 265 besides the new Falken 452 size 285 which has recently replaced it. The Falken 451 tyres were heavily worn on the inner edges before I fitted the camber/caster brackets and the even tyre wear acroos the full width, shows how running with minimal negative camber equalises wear across the full tyre width, thus improving the contact patch and improving rear grip.
topfuelking
stu wrote:pdf link no worky for me Marc
http://www.bavauto.com/shop.asp#undefined
it's the 3rd one down bud
THANKS MARC
topfuelking
cleomantra wrote:Hi TFK do you have any pics I would like to see what it looks like before I go and order a set
Cheers Berti
no sorry but you can see them on the links
THANKS MARC
topfuelking
exdos wrote:I bought a set of these things (from AKG in the US) about 12 months ago, but sent them back, because when I properly examined them, I couldn't see how these things will maintain their settings over the longer term, bearing in mind the forces involved.
yes bud the weld in ones must be the best..but if the one i have need setting up after 6 months and i get the tyre wear you are getting i will be very happy
THANKS MARC
Well, here's to resurrecting a very old thread.
I'm getting very bored of constantly feeding my car tyres due to the excessive rear camber.
I need an adjustable or improved toe in kit.
Anyone done this recently?
exdos
  M coupe S54
Post by exdos »
Bite the bullet and get IE's camber and toe brackets fitted.
The wear on my rear tyres is so even across the 285mm width and the roadholding is superb because I get an excellent contact patch.
Post by maurice the martian »
Think i need one of these kits,any suppliers in england?
Maurice.
Thanks Exodus and TopFuelKing (a while ago!)
The welding option seems quite extreme but tempting and the description from http://www.bavauto.com/shop.asp sounds good to me. $250 seems a fair price if they save my tyres!
Optimize rear camber to maximize performance or tire wear. Bavarian Autosport's adjustable rear camber correction kit lets you fine-tune camber to suit your purpose, whether it's better handling at the track or prolonging the life of your rear tires--especially important if you have lowered you BMW's chassis or installed 'plus size' wheels. Kit comes with a handy tool for installation and removal of bushings.
I shall start investigating further
exdos
  M coupe S54
Post by exdos »
The welding option is the best option though.
Personally, I think that the correction of toe (zero toe angle best) is more important than camber.
