I’ve read the various posts on changing pads and discs, in particular Mike F’s “how to” guides. My problem concerns RIDGES on the rear discs with corresponding grooved in the pads.
The pads are worn and will be replaced but do I need to change the discs as well? Mike’s article refers to grooves in the discs (eg caused by a trapped stone) but I have the opposite situation.
In physical terms the reduction in contact area will be small and clearly new pads will soon re-groove to match the disc profile but is this acceptable? There is plenty of thickness left in the discs.
What would you recommend – new discs and pads or just pads?
Titan
New discs required or not?
- Justin Time
As you say, the pads will bed in to the profile of the disc.
Unless your discs are severely worn, ie there is a pronounced lip around the outer edge, badly corroded or warped, I would only replace the pads.
From my experience, it is normal for the disc to develop fine ridges around the braked area , which I believe is largely due to the type of material that is used now to manufacture the pads.
Malc
Malc
New Discs
Thanks for all the replies Guys
I was going to post pics but the weather up here is not very conducive - glad we didn't remove the hard top last Saturday.....
On balance, I'll bow down to SpunkyM's scintillating sintering and opt for new discs
Titan
Titan
