my new wheels 18 inch AC schnitzer reps - tyres?
Morning everyone
Well I have purchased my 5th set of wheels for the Zed.
These are my next project.
Just a quick question about tyres
The wheels are (all)
ET38
18x8.5J
What tyre size do I need?
255/35 rear
225 or 235/40 front?
They have come with a real mixture of tyres!
ET38
18x8.5J
255/35 rear
These are the sites that I used when choosing tyres for mine:
http://www.willtheyfit.com/index.php?wi ... mit=Submit
http://www.tyrestretch.com/
Hope it helps!!
Hope it helps!!
You are trying to keep the diameter of the front and back almost the same.simonbud100 wrote:Sorry to ask a thick question but why have a lower profile on the rear? My car is fitted with exactly the same fitments as above, hence the question.Dav wrote:Personally I would go 225/40/18 front and 255/35/18 rear.
The overall diameter is made up of the wheel, in this case 18 inches, plus the section height of the tyre. The section height is the distance from the wheel rim to the edge of the tyre.
The section height is calculated by taking a percentage of the width of the tyre.
In your case, in simple terms, 225/40 (fronts) the tyre is 225mm wide with a 40 profile so 40% of 225 is 90mm. The rears are 255/35 so this is 255mm wide and the profile is 35 so 35% of 255 is 89.25mm and therefore the fronts and rears are keeping almost identical diameters.
Hope this helps
Dav the wheel nut
Fitted today, Continental Contact sport 3 on rears 255 35 18 and pirelli rossa 235 40 18 on front.
Not sure the pirellis will last long, seemed a little scuttley on the way to the body shop for my nose job!
I like the look of them though!
What do you lads and lasses think?
Bit like my old ones,
Re: my new wheels 18 inch AC schnitzer reps - tyres?
Gents, need a bit of help please. I have similar 18 inch 8.5J wheels but appear to have a ET40 offset. The fronts are fitted with 235/40 and the rears 245/40. I need to replace all 4 tyres and am concerned about the fronts as they currently appear to foul the inner arch on full lock. What size tyres should I be fitting (front and rear) and do I require spacers?
Thanks in advance
Thanks in advance
1999 2.8 Arctic Silver Z3
2007 325d Msport - remapped
225/40/18 shouldn't give you any problems
On the fronts only Gaz? Was thinking 225/35 on the rear?
225 on the rear will look a little small IMO
Spacers aren't needed on the front with 8.5" and ET40
245/45 is normal for the rear even on 7.5" rims
The Schnitzers on mine 8.5x18 ET43 or ET36 with 7mm spacers front and rear were fitted with 225/40 fronts and 255/35 rears. IMHO 235 is too wide for the fronts and increases the possibility of tramlining.
I'm now running 225/40 on 8x18 rims front and rear and in all honesty they look fine on the rears, yes you don't quite get that wide tyre stance when looking at the rear but the biggest bonus I've found is in the handling, the Zed just feels much more nimble and chuckable in the corners. The wider rears somehow seem to make the car more leaden and slow whitted. With going for all season tyres which are softer compound the ride is much better too
The addition of spacers does not alter the ET of the rim. The ET is the measure of offset from the centre line of the wheel to the mounting surface.TitanTim wrote:The Schnitzers on mine 8.5x18 ET43 or ET36 with 7mm spacers front
The higher ET puts the mounting surface toward the outside of the rim.
Not physically but theoretically for e.g. a wheel with an offset of ET43 if you fitted a 7mm spacer pushes it out making it in theory the same as wheel that was manufacutured with an ET36 offset? i.e. it makes the offset lower or am I talking or should read theGazza wrote:The addition of spacers does not alter the ET of the rim. The ET is the measure of offset from the centre line of the wheel to the mounting surface.TitanTim wrote:The Schnitzers on mine 8.5x18 ET43 or ET36 with 7mm spacers front
Correct, if you add a 10mm spacer it effectively reduces the offset of the wheel by 10mm.
ET43 Wheel + 10mm spacer = Effective ET33
Cheers si thats kinda what I was thinkingsiwilson wrote:Correct, if you add a 10mm spacer it effectively reduces the offset of the wheel by 10mm.
You're both wrong.
Theoretical and effective don't come into it, by adding spacers you only change the position of the whole rim relative to the mounting surface. ET or offset is the difference between mounting surface and the edge of the rim.
If I stand on a 6" box I'm not now 6'6" tall, I'm still 6' but standing on a box !
I'm still not convinced Gary I know what your saying though :winkGazza wrote:You're both wrong.
Surely fitting spacers changes that difference as you say between the hub and outer face of the rim and that's the change in offset:?
Fitting spacers only pushes the whole rim out, the ET of the wheel remains the same.
Perhaps this will make it clearer http://www.1010tires.com/WheelOffsetCalculator.asp
Gazza wrote:Fitting spacers only pushes the whole rim out, the ET of the wheel remains the same.
AC spacers are permanently fitted to the wheel using a spring clip so that they are always on the wheel, and are not fitted to the hub, so this has indeed made the 'wheel' a different offset as the position of the mating faces is now different.....
I'm afraid your all wrong..
Spacers = cool dude
No spacers = booooo!
Nuff said..
Spacers = cool dude
Nuff said..
gookah wrote:Gazza wrote:Fitting spacers only pushes the whole rim out, the ET of the wheel remains the same.
Agreed, the wheel now has a different offset/ET
Fitting a spacer to the hub does not change the offset/ET of the wheel, fitting a spacer to the wheel does. It is the relationship between centreline of the wheel to the mounting surface of the wheel that gives the offset/ET figure.
The box doesn't change my height, only my relationship to the ground.
If the box was surgically applied to my feet then I would have a height of 6'6"
Think of the spacer as the box
