Hi, All
can you help? I would like to widen the look of the rear instead of fitting wider tyers I'm looking at wheel spacers what is the max wheel spacer I can go upto?
and will it effect the front? + steering the Z is a 2.8 wide body
Regards Bazza
Wheel spacers
Re: Wheel spacers
You need to know what offset your wheels are, you can then workout what size spacers you need.
Re: Wheel spacers
You don't need to know the offset if the wheels are already on the car.Captain wrote:You need to know what offset your wheels are, you can then workout what size spacers you need.
Just measure as suggested above.
OEM Z3 wheels are usually 10-15mm
Make sure you get the correct Pcd and bore and they are hub centric at that size.
Factor in the cost of longer bolts / locking wheel nuts as well. Standard are 26.4mm so with 10mm spacers you will need c37mm etc. Get them advertised for a Z3 so you get the correct thread etc...
Re: Wheel spacers
Thanks lads
