Z3 / Z3M suspension intercompatibility
mnbrennan
Post by mnbrennan »
Hi all
Just wanted to know whether z3 suspension will fit onto a z3m?
Sent from my HTC One using Tapatalk
Now: '99 Z3M Coupe in imola red
paulwirral
Re: Z3 / Z3M suspension intercompatibility
Post by paulwirral »
Front springs are different diameter , I'm pretty sure the rears are the same , careful fella , mc mafia won't be happy your on a roadster site :lol:
mnbrennan
Post by mnbrennan »
Haha you're right, but there are more people here!
I'm thinking about coilovers for the front and lower springs for the rear. Will they fit?
paulwirral
I can't see why not , the rears will be the same and I can't see the fronts mounting any differently , you may need spacers .
Ring someone like demon tweeks and ask them making on your gonna buy a new set from them , they will be only to eager to find out for you :D
Post by pingu »
You will see the differences if you look at real OEM for a standard Z3 and your car. Print off the appropriate pages and compare the part numbers to see the differences.
There are quite a few differences in the stiffness and offsets of mountings, castor settings of the front suspension as well as spring and damper settings.
If you are considering a complete change of suspension, then this is possible, but most individual components are not interchangable.
