Any Plumbers in the House?
Hi all,
Does anyone know much about household plumbing
We had some new taps fitted 5 weeks ago, mixer in the kitchen and usual basin taps in the bathroom, the plumber fitted a pair of in-line shut off valves for the hot and cold pipes in the bathroom. Ever since they have been done we now get a continous whooshing sound through the mains pipes, I think the cold water pipes. If the mains stopcock in the house is closed the sound goes.
I have tried a number of things to get rid of the noise i.e. closing the stopcock, running all the taps, flushing toilets and then turning mains back on. The taps will glug glug, spit water out, i.e. expelling air and then will run smoothly. The whooshing sound in the pipework disappears but returns again after 24hrs
Reading on the internet and the symptoms I have, implies that there is a pressure leak someone, i.e. a water leak somewhere in the house, however have checked everywhere, loft, most of the pipework but no leaks, there is no mains pipework under floors (bungalow) so at a loss.
Anyone had this problem before?
Cheers,
Cheers,
- Z Register organiser
Check storage tank--If fitted?.
Have you checked the water level in the cold water storage tank in your loft? If low, when you use the hot and cold fittings(not main at sink unit) it could be sucking in air.
safetyfast
i am a plumber, noise can be a hard one sometimes because of the way it travels through the pipes but nearly always its a ball valve. either on a toilet or from a tank in the loft, this could of started then either because when your plumber worked on the pipes he may of got a little dirt in the pipes and that would find its way to a ball valve or just the decrease in pressure when the wanted was turned off can sometimes do this. what type of system do you have? combi boiler? unvented mains? open vented?
You've probably done this already but if not it's worth checking all the bathroom overflows, sometimes the float valves stick intermittently and allow water to continue after flushing.
Also it can be a burst outside the house sending the noise through the pipes though probably not in your case.
Dave.
Dave.
Something like this might help?
HT
How to Keep Water Pipes From Howling | eHow.com
http://www.ehow.com/how_6912661_keep-wa ... wling.html
HT
gookah wrote:NickDale wrote: no wonder i stopped posting here!
"Oh no you didn't".......
HT
Titan's apprentice.
Titan's apprentice.
Official Devil's Advocate
Leg Puller
Micky Taker
Thanks for the replies everyone, really appreciate itNickDale wrote:i am a plumber, noise can be a hard one sometimes because of the way it travels through the pipes but nearly always its a ball valve. either on a toilet or from a tank in the loft, this could of started then either because when your plumber worked on the pipes he may of got a little dirt in the pipes and that would find its way to a ball valve or just the decrease in pressure when the wanted was turned off can sometimes do this. what type of system do you have? combi boiler? unvented mains? open vented?
Nick, thanks for your reply, the ball valve for the toilet cisterns are OK. We have a seperate gas boiler and hot water tank and I think the loft cold water tank is vented as I remember when we had the bathroom taps done before we got alot of air in the system which prevented waterflow to the taps and the plumber had to vent the cold water tank which sorted it.
I have just shut the water off again, opened the cold water taps until dry, closed them and quickly turned the mains back on again. The sssshhhhhh sound in the pipes has gone again now and the system is totally silent. I'am wandering if it is air getting in via the cold water tank, hence why the sound returns after 24hrs I thought though you could only get air in the hot water pipes and not cold I guess next thing is to check the cold water tank. The ball cock in the cold water tank was replaced a few years ago as water was trickling out the overflow so isn't very old.
The noise that can be heard isn't loud and gets drowned out by the central heating etc, but when everything is off the sssssshhhhh noise can be heard
Cheers,
Cheers for that, have checked cisterns and seem OK, we don't have any external taps so can't be a problem. Just puzzled as to why if the mains is turned off and taps drained and then back on the sound dissapearsOXO wrote:you need to go round the system shutting off anything that can be. My guess is the same as above, that it's a toilet cistern. But also check outside taps - one in the garage or garden?
you don't need much of a drip to make a sound...
mains pressure cold water shouldnt ever get air in the pipe work and make a noise so it wont be on the cold if its not on a float valve. the main reasons for noise in the pipe work would be;
1) unclipped pipe work, its not going to be that as your pipe work hasn't changed.
2) air in the system, very little chance of this as all hot taps are running i presume? and mains pressure cold wouldn't trap air.
3) a float valve, could be a toilet or tanks in the loft if you could isolate any of these you mite get your answer. i think I'd start with your cold water storage tank in the loft (the big one if you have two) if you cant isolate the tanks try sticking your head up in the loft when you hear the noise, see if its any louder. these dont have to be overflowing to be a problem if they trap dirt they can make noise even if you open a tap elswhere in the house.
Nick
Nick
Hi Nick,NickDale wrote:mains pressure cold water shouldnt ever get air in the pipe work and make a noise so it wont be on the cold if its not on a float valve. the main reasons for noise in the pipe work would be;
Nick
Thanks very much for your reply, much appreciated. Noise hasn't returned since yesterday so as you suggest will poke my head in the loft if it returns, we have just the one cold water tank in the loft. I'm just puzzled as to why the noise disappears if you turn the mains off and back on and then reappears some 24hrs later If it was a faulty float valve then wouldn't the sound reappear straight away once the mains was turned back on again?
Cheers,
Possibly not. If there is some damage or grit in the valve, it could be that the pressure is preventing it from seating properly after it has been opened. Once you reduce the pressure by turning it off, the valve reseals. Only later when the valve opens and closes again does it have the problem again... ?TitanTim wrote:Hi Nick,NickDale wrote:mains pressure cold water shouldnt ever get air in the pipe work and make a noise so it wont be on the cold if its not on a float valve. the main reasons for noise in the pipe work would be;
Nick
Cheers,
Hi Ray,Boysie wrote:Hi TitanTim
I have come across this several times in clients lofts,
where people have done a DIY job and fitted a service valve
this has a restricted flow.
"You must remove it and fit a mains stop cock"
Ray
Thanks, the cold water tank in the loft has a standard ballcock float, which was replaced a few years back with a new one by a plumber, has worked fine and no problems, until we started getting this ssshhhhh noise through water pipes which I think started when we had kitchen and bathroom taps replaced a few weeks back.
Funnily enough I switched the mains water off at 6pm Sat night and back on and noise has gone and hasn't reappeared, toilets, taps, shower have all been used today. I'm hoping the noise has gone for good now
Yep, that's it.TitanTim wrote:Had a nose in the loft, and can hear a continuous trickle of water going into the cold water tank, which would explain the continous ssssshhhhhhh noise in the water pipe going up into the loft. I guess the ballcock valve isn't shutting the water off once upto level?
It's an easy thing to change yourself. Off to the plumbers merchants with you !
I would be very surprised if thats the answer,
the ballcock leaking would not cause a noise in the pipes
you descrbe a rushing noise?
I have had that noise in pipes when there's a leak in the mains supply
inside or outside the building the sound travels
shame your not close by
There is an old fashion way to detect leaks, the water board still
use the method to this day.
Put a piece metal resting on the pipe and other end to your ear
You will hear the noise of the water rushing if leaking
Ray
Ray
Ray
I can't think what else it could be, if you switch the mains off inside the house the noise goes. I understand if the noise was still there once the inside mains was shut off it could be leak outside so can't be that. There is definitely no leaks inside the house.
The sound is like when the cold water tank is filling i.e. rushing of water through the pipes but its doing it all the time instead stopping once the tank is full. Its the only explanation I can think of as if the tank is filling all the time and the water not shutting off then I would have thought you would get the pipe noise continously which is what its doing. When I checked this morning I could hear water going into the tank continously and not being shut off.
Plumber is coming tomorrow morning to check the ballcock etc. The cold water tank in our loft is a swine to get too as being in a bungalow with shallow pitched roof you need to be the size of a hamster.
Thanks for the responses,
I had the same problem with the ballcock not closing fully, and it was continuously allowing a slow dribble of water into the tank.
The excess water overflowed out of the overflow pipe, and would turn into a torrent when the central heating kicked in (why the central heating increase the flow I don't know).
I never had any noise from the pipes during this, so this possibly isn't the cause of your noise.
