M Roadster Engine oil
Zippy181054
  M roadster S52
Post by Zippy181054 » Mon 05 Feb, 2018 23:55
Anybody out there have a firm oil specification for an M Roadster? Getting a bit confused with different forum responses :head:
Dr. Wilson
  Z4 M roadster
Re: M Roadster Engine oil
Post by Dr. Wilson » Tue 06 Feb, 2018 19:59
Can only recommend what I use, as I found out the same in that there were many diff rent opinions! As recommended by my M service specialist, my own S50 M Coupe uses Castrol Edge 10w 60 with no issues whatsoever.
woodsta888
Post by woodsta888 » Tue 06 Feb, 2018 20:07
Opie Oils have 15% off everything and their prices are good to start with.
https://www.opieoils.co.uk/t-Current-Offer.aspx
ENDS TOMORROW MIDDAY!!!!!
Zippy181054
  M roadster S52
Post by Zippy181054 » Tue 06 Feb, 2018 22:10
Are you track racing your coupe? This will make a massive difference to standard road car requirements
Post by pingu » Wed 07 Feb, 2018 18:41
That is the correct oil for the S54.
The BMW oil data sheets are here...
http://www.porterbility.com/BMW_Oil_Sheets.htm
Enclosure 8 shows the correct oils for the S50.
Dr. Wilson
  Z4 M roadster
Post by Dr. Wilson » Wed 07 Feb, 2018 19:37
As I say, can only recommend the oil I use and defer to a greater knowledge or reference.
Sent from my SM-G935F using Tapatalk
