Hello all
I've just made the best purchase of my life... A lovely, '00 Z3 3.0 in Topaz Blue and I love her to bits already. Bought her off a fellow forum member and I was impressed with how friendly and helpful he was Loved the 200ish mile drive home and loved it even more after going for a cruise over the Brecon beacons yesterday However She has been pampered and NEVER driven in the rain before and unfortunately Wales being what it is, it's tipping down and my soft top has developed a slow drip from where the leading edge of the window meets the join between the soft top and the windscreen.... Advice/Help please??
Newbie Alert!
Re: Newbie Alert!
Welcome to the world of happy motoring
Had similar problem with mine, that unfortunately sleeps outside, as a 16 year old convertible some leakage goes with the joys of owning a soft top.
One product made a massive difference Gummi-Fit by Wurth and now only get a drip when washing.
Its like using a shoe cleaner with a foam pad attached, it is silicone based and not sure if available in the UK so need to probably get of E Bay. Easy to use and i for one very pleased with results.
Re: Newbie Alert!
Welcome to the forum and you have picked up a cracking car being a 3.0 not that I'm bias at all !!
Gummi pledge helps soften the rubber seals as them become harder over time and making the rubber more supple may help to better seal against the window. You can get it off ebay
Re: Newbie Alert!
She is a beaut
Thanks Guys, I'll have a little look. also thinking of proofing the soft top with some auto-glym.. might help eh?
Re: Newbie Alert!
Always worth looking after the top, not sure proofing will help with the leak
Re: Newbie Alert!
This link might help.
http://www.zroadster.net/forum/viewtopi ... 12#p345112
From my own experiences I would guess that the most likely problem is the rubber "stoppers" at the top of the windscreen pillars - the leak caused by them tends to run along the side window a bit and drip onto the side of the seat.
Re: Newbie Alert!
As Del has said, quite possibility the rubber grommits at the top of the pillars. Drop the roof down, push the grommits in about 1/4 inch on both sides and fill with clear silicone. Smooth it off for aesthetic purposes and allow to dry properly. Did this with mine and they've never leaked since.
Dave
Dave
