Hi all - new member with pics
Hi everyone;
New Z3 owner and new member to this forum, had a good look through the posts and the forum looks really helpful.
Anyway have bought a really nice 1997 1.9 Z3, not sure of the colour its dark blue metalic but looks a bit indigo / purple in the sun?, here are some pics:
Its had a new roof (though the window is cloudy) and considering its done 122k its pristine inside and outside, with very good paint.
It drives very well, though Im going to give it a good service as I dont think its breathing as well as it could.
Some silly questions you may be able to help with:
When I start to take the roof down, after about 12 inches or so I meet a lot of resistence and have to push hard for it to continue to go down - is this normal or should I be doing something to ease the task (a button/leaver etc.?)
Service - is there undercovers fitted that need to be removed to get at the oil filter - or even better is there a service guide on here ?
Do the HT leads need replacing on these often or is it best to leave well alone if they are doing their job?
I used to have a Z4 (before the kids went to Uni - bank of mum n dad lol) but before I sold kept the split rim 18" 108 wheels - will these fit the Z3 without any probs? Anyone have them on, and any pics?
What are the typical Z3 problems I can expect to come across - dont hold back I've just sold an MR2 so Im used to problems ha ha
Anyway enough questions for now - looking forward to having some fun with this
Mike
Mike
- Attachments
- Z3 PIC2.jpg (48.24 KiB) Viewed 2503 times
- Z3 PIC5.jpg (54.96 KiB) Viewed 2503 times
- Z3 PIC6.jpg (40.71 KiB) Viewed 2503 times
- Z3 PIC11.jpg (46.79 KiB) Viewed 2503 times
- Z3 PIC12.jpg (44.98 KiB) Viewed 2503 times
- peterandjenny
Welcome to the Forum
If your roof is electric, you need to keep your foot on the brake and keep the button depressed.
- hornel Z3M
z
If your roof is not electric you can help the drop by pushing the roof lining down between the roof bars, ie make the fold tidy. I had a 1.9 and never had a problem with it. oil services are the best treatment and fit a K+N exposed filter to make it sound and breathe better.
Re: z
A 1997 won't have a roof lining unless it has been retrofitted.hornel Z3M wrote:If your roof is not electric you can help the drop by pushing the roof lining down between the roof bars, ie make the fold tidy.
It sounds like a car with an electric roof, which has perhaps had the valve released in the boot to allow it to be operated manually. Easiest way to tell is does it have an up/down switch for the roof either on the front console below the heater and vent controls, or in the little panel between the seat backrests. If no switch is apparent, check in the boot behind the left-hand side trim - if there is a large silver cylinder with a reservoir attached to it, you have a leccy roof.
Welcome to the forum BTW.
- hornel Z3M
z
Ok i meant the roof fabric
Thanks chaps
Was going to take the zed out this weekend and have a good poke around but decided to leave it in the garage coz of the snow!
Fou d the oil filter canister doh, went and bought the removal tool and servicing items so will do that next weekend
No switches in the cabin that are unaccounted for and the cd stacker is in the way of getting the side panel off in the boot, but don't think it's a leccy roof, but will try and remove the panel next week to be sure
Does everyone always replace the copper washer on the sump plug?
Bring on the summer
Bring on the summer
- Z Register member
Lovely standard, unmolested Zed with a very clean interior by the looks of things. Nice to see the original wheels on a Zed too!
In your first post, you mentioned that you didn't know thew colour - its Montreal Blue.
Just lose the air freshner and it'll be perfect!
Good luck with the car....and welcome to the forum!
smartypants wrote:Conor?
With an M??
The World's gone mad
Hi Mike
Welcome to forum. I acquired my Z3 (1998, 1.9 M44 engine, 17 inch wheels) last June and I have been working my way through a small list of renovations to get it back to original condition as far as is reasonably possible. The things I’ve encountered are:-
• Tram-lining - seems to be a common mention and some people eradicate with tyre pressure adjustment.
• Slight seat movement back and forth (worn bushes). Cure mentioned on this forum.
• Sticking/slow electric windows - requires removal of door card and good lubrication.
• I had a slight damp issue in the boot – cured by a new aerial grommet.
• The rubber boot between the MAF sensor and inlet manifold on lots of cars is prone to perishing with age and so can let in “un-metered” air. If you have the M44 1.9 engine this can be exacerbated by the rubber branch that comes off this boot which splits into 4 small hoses that feed air to the 4 injectors. The hoses just harden and split with age. Replacement requires removal of the upper manifold – not difficult.
• The textbook advice is to replace the copper washer under the sump bolt with each oil change. I must admit that I never bother; I just wipe it clean and reuse it. I have never encountered an oil leak on the numerous cars I’ve had over the years.
• The 1.9 engine is said to be a tough and reliable engine. I’m sure others on the forum will agree – BMWs like good quality, fully synthetic engine oil of the correct viscosity.
• I have talked to a senior BMW technician about replacing the HT leads and he told me that he’s never needed to replace a set. The OEM ones are high quality made (I believe) by Bremi. I tested the resistance on mine with a simple hand held meter and it was consistent and correct at around 5k ohms.
• If you have a manual soft top I agree with what Hornel Z3M said. I find the top just needs a little bit of help folding at times.
• There are products on the market to help with the cloudy rear window. Mine wasn’t too bad and I’ve cleaned it with some stuff called Greygate.
My own research i.e. talking to mechanics etc. leads me to believe Z3s are tough, reliable little cars that don’t seem to have any particular, serious in-built faults. The build quality seems very good to me.
Derek, North Somerset
Thanks folks for all of your kind comments, and Derek this is a useful list of hints you have put together, thanks, recognise the seat shifting problem on mine and the boot smells a bit damp too so will investigate
Will do the service this weekend hoverer based on Derek's recommendation for fully synthetic oil I may have to change the stuff I have bought - I have 10-40 semi synthetic which was what Halfrauds recommended - is this no use then? If not is it 5-40 fully synthetic I should be using?
I have a service book but no handbook to check myself
Mike
Mike
I don’t know your precise model but I would say you require something like fully synthetic 5W-40 engine oil. You can do a check on the Mobil and Castrol sites. Many drivers have strong views about oils and brands and so I wouldn’t be as bold as to recommend a particular brand on this site. Personally, I am happy with the less famous brands (at lower prices) as long as it has a rating such as the above. My own view is that frequent changes are more important than a precise brand.
