Roll bar all in one for BMW Z3
- BlackBeautZ
Hi guys I have a 1997 Z3 I have ordered all in one chrome hoops so just the ends slot into the seat belt mounts, however on opening the plastic caps by the seat belt they are solidly stuck on with glue I broke one and I can't see a nut in there or there is this plastic rubber in the way, will the till hoops fit or will I need to buy a whole new back plastic compartment box ? Please help
Kris
Black BeautZ
Black BeautZ
Re: Roll bar all in one for BMW Z3
What you're seeing in there sounds like a moulded styrofoam type plug...you may have to remove the top trim to get at it and remove it...
The turrets are often filled with polystyrene with a plastic cap located into the top of the roll hoop mount. There a couple of pics in this post of the inside of the turrets on my car when I fitted an OEM wind-defelector prior to doing the full rollhoop conversion. I removed the turrets and cut the polystyrene from the inside, but if can be done from the outside if you have something like a dremel - the plastic caps seem to be made of indestructium!
