Project PFL 969
PFL969
Project PFL 969
Post by PFL969 »
My to do list:
MOT Done / passed 14.2.2014
Oil Leak I think this was in my head - not really noticed anything 25.2.2014
Stereo. Sub and head unit work - prob with front speakers. Oh yes this is fixed 22.2.2014 Morel 4" speakers (co-axial) in the rear and 5.25" components in the front...but possibly needs a proper 4 ch amp to drive the speakers cleanly
Sub enclosure rattle Rattle but no Hum. I have foam, will experiment.
Brake light. 10.2.2014 - fixed, with new sockets and gasket
Hood not working. 7.2.2014 - fixed
Rear tyres 6.2.2014 - replaced Michelin PS3
All wheel refurb
Front bonnet / bumper respray Have quotes, need more.
Front light bulb change
Flat battery. 1.2.2014 - replaced
Drivers side floormat. New set, replaced 19.2.2014
Worn steering wheel
Passenger electric seat Diagnosed by Joycey failed switch - 15.2.2014. Rather selfishly I'm not that bothered as I don't sit in it. :evil:
Fuel smell
Spark plugs
Diagnostic
Clean car! Sort of done by the Eastern European fellas. It's OK but will wait till I've Renovo'd
PFL969
Re: Project PFL 969
Post by PFL969 »
C110 scanner arrived today let's see what it brings up. :P
PFL969
Re: Project PFL 969
Post by PFL969 »
Airbag light is on because of 05 Firing circuit, belt tensioner (driver). Whatever that means?
Re: Project PFL 969
Post by Brian H »
PFL969 wrote:Airbag light is on because of 05 Firing circuit, belt tensioner (driver). Whatever that means?
There is a 2 pin connector under your seat that connects to the seat belt tensioner (the part your seat belt clips in to) moving the seat backwards/forwards can disturb this connector and throw an airbag fault, clear the code and see if comes back. If it does not do not worry, if it does check under the seat for the connector.
PFL969
Re: Project PFL 969
Post by PFL969 »
Thanks Brian. Fault cleared but hope the airbag works!
PFL969
Re: Project PFL 969
Post by PFL969 »
C110 Scan Results
DME Digital motor electronics - SW-V32. Part 543611. No faults
EGS Transmission control 1406611. No faults
EWS Electric immobiliser. No faults
GR Cruise control. Communications error
EML Electronic throttel. Communications error
ABS 94 be vehicle voltage >16.5V
10,02,01,00 No found (no idea what this means)
ADS Throttle valve control -9V Voltage 10,02,01,00 (agin no idea why this means)
EHC/EDC Communication error
Communications errors for ZKE Centrl body electric, CUM Convertible top module, IHKA/IHKA ac/heater, IKE/IKI/KOMBI instrument cluster, LSZ/LCM Light switching Central, multi-information display, RAD Radio, SHD, SPM/SM, Rollover system, UMX Variable camshaft.
AHK Active rear axle 002F (?)
EKM Electronic body control 002A (?)
FHK Rear heater system 002D (?)
GSA Closed loop controlled differential lock 002E (?)
XEN xenon lights 002C (?)
PFL969
Re: Project PFL 969
Post by PFL969 »
Big thanks to zederbee for hooking up the car yesterday with the INPA software. A couple of old errors were thrown up but nothing too major. One error which we couldn't fathom was a charge of greater than 16.5 V going to the ABS. Odd but we didn;t have a multimeter to conduct more tests.
MOT day! Hope its a happy valentines day for PFL969
Joycey
  M roadster S52
Re: Project PFL 969
Post by Joycey »
Good luck mate! :P
PFL969
Re: Project PFL 969
Post by PFL969 »
PFL969 is now officially back on the road :squeeze:
PFL969
Project PFL 969 - Passenger Seat
Post by PFL969 »
Just wanted to say a big 'thanks' to Joycey and his Dad for spending countless hours last Saturday helping with sorting out he cars issues.
One of the problems with the car is the passenger side electric seat. They took the seat out and cleaned the underside. The two motors were tested using a 12v car battery. The relays etc were all fine. The problem has been isolated to the actual switch for operating the forward / aft and up / down movements. I can;t seem to get 'just' the replacement switch and BMW only replace the whole of the underside of the seat (includes wiring loom and the metal bit) - that costs +£630 +VAT.
Has anyone else had this problem, if so what was your fix? Southernboy suggested an ebay search for E36 or Z3 electric switch. Unfortunately nothing suitable is listed?
Another seat issue was the lateral movement from the seat under acceleration / deceleration - the Joyce's identified that this is a seat bush problem and I have ordered one from Aceman.
Thanks for reading.
Re: Project PFL 969
Post by Southernboy »
Left hand switch only ~ 61318413893
Right hand 61318413894.
Aprox US $. 155 each. ex BMW.
Re: Project PFL 969
Post by bertiejaffa »
I think seasurfer has a seat button....
PFL969
Re: Project PFL 969
Post by PFL969 »
Hi Southern Boy,
OK the part numbers you've listed are for Z3's with standard seats (July '97-onwards) ending 893 is for the passenger side, ending 894 is the drivers side.
For people with M seats, passenger side ends 895 and driver's side is 896
Re: Project PFL 969
..... so, are you saying that now you have the part number for the switch only, you can't buy it as a separate part?? :puzzle:
Re: Project PFL 969
Post by Brian H »
PFL969 wrote:Hi Southern Boy,
Coopers BMW are showing them online at a stupid price of c£223.00 ea :shock: Click Here, this of course does not mean it is a stocked item. Best bet is to try a breakers yard.
Image Switch, seat adjustment - BMW parts catalog
Re: Project PFL 969
....I'm sure she does have a seat button...but is it an M button ? :wink:
PFL969
Re: Project PFL 969
Post by PFL969 »
Yep, I called Coopers - that's some switch for £223.00
Joycey
  M roadster S52
Re: Project PFL 969
Post by Joycey »
Fez there is a selection of breakers in our area mabye worth going for another drive :lol:
Re: Project PFL 969
I needed heated seat buttons and sea surfer contacted me to say she had one. It turned out to be a seat button rather than a heated seat button (ignore Barry's smut)
Re: Project PFL 969
You'll have us in tears next Lee ... :devil:
PFL969
Re: Project PFL 969
Post by PFL969 »
:lol:
Re: Project PFL 969
humph... I will keep Seasurfer's button for myself :twisted:
PFL969
Re: Project PFL 969
Post by PFL969 »
Bit cleaner........
Joycey
  M roadster S52
Re: Project PFL 969
Post by Joycey »
How did your quotes go for the full respray?
I have see this being mint when you have finished.
Joycey
PFL969
Re: Project PFL 969
Post by PFL969 »
Gracias Señor
Quotes so far for bonnet, fix front bumper and respray are:
£500+VAT Bodyworks, Camberley
£850+VAT Antons Garage, Blackwater
Waiting for Perfect Paint (Sandhurst) and St Georges Coachworks (camberley)
What I noticed yesterday is a loss in rear wheel traction on hard acceleration from c 4,500 - 5,000 rpm. Tyres are scrubbed in / dry road / good ambient temp. Poss springs or shocks?
Re: Project PFL 969
Post by Del »
PFL969 wrote:Poss springs or shocks?
Could be tired shocks are a contributory factor. If they are not dampening the oscillation of the springs sufficiently, the tyres will be continually losing contact with the road surface resulting in loss of traction and greater braking distances. It can also cause uneven or excessive tyre wear (tyres continually bouncing and scuffing). Alternatively, as I haven't driven an M it may just be a characteristic of the car and pushing 300 BHP + through the rear wheels. :D
PFL969
Re: Project PFL 969
Post by PFL969 »
I think it's the shocks too. :bawl:
Joycey
  M roadster S52
Re: Project PFL 969
Post by Joycey »
PFL969 wrote:I think it's the shocks too. :bawl:
I would go with the shocks too, After chasing you in my zed and me throwing it into the roundabout trying to keep up scared me a little. I wont lie a little bit of wee came out :lol:
It didnt feel confident and responsive going in and coming out of that roundabout.
Might be worth ordering some shocks to go with those springs and we can change them on a weekend :o
Re: Project PFL 969
Post by Brian H »
Joycey wrote:I wont lie a little bit of wee came out :lol:
:lol: :lol:
PFL969
Re: Project PFL 969
Post by PFL969 »
I knew there was a smell in my car - I thought it was the damn cat again! :shake:
Just waiting for call back from a PPCGB I think they're called - looking for the original (?) Sachs shocks.
Just put some Renovo cleaner on the roof, left it an hour and done the first bit of scrubbing - oh boy was it grim...Might need another couple of applications and scrubs.
PFL969
Re: Project PFL 969
Post by PFL969 »
Three applications of Renovo Hood cleaner.....
PFL969
Re: Project PFL 969
Post by PFL969 »
Revovo cleaner is very good, I gave the hood three applications and the muck comes off with a bit of scrubbing with hot water.
Cleaning the hood revealed some serious fading as shown in these photos.
I applied one coat of the soft top reviver and will take / post a pic later today when it dries out. I bought the 500 ml kit from ebay (cleaner, reviver, proofer) for £36 ish
