leaking roof
leaking roof
my roof leaks a little in the rain. not really enough to cause concern, but it is a bit annoying that there is a few spots of water on the seats after a long shower.
is this normal? looking through my car's service history it says the whole hood was replaced under warranty a few years ago due to a leak.
There are lots of threads on here about leaking roofs - you should try a search. It sounds like yours is leaking through the seals above the doors. Make sure you raise the hood with the windows down a bit then raise the windows last. That may sort it.
Its a very common problem with Z3's, and probably most softops.
I have a leak in 2 places, but just on the drivers side. Its where the bends in the roof are.. the window doesn't meet the top seal tight enough, and with the gaps in the roof bends it drips alot.
My dad fixed this problem for me by cutting parts of thick rubber, in the shape of the roof joints, and glued them on with some sort of super glue/sealant stuff, and the leaks stopped.
There are many threads on this topic, and someone does have a picture up somewhere, showing they did the same (with the cut out bits of rubber).
Suzy
when I first got it, my zed's roof leaked badly in heavy showers; both seats (cloth at the time) were soaked after a downpour. I took it in to the garage & they adjusted the hinges on the roof & it doesn't leak at all now (unless I open the door, lol!). You haven't had yours that long have you Edd - take it in to the garage.
Suzy, you have PM.
burmagirl
Suzy, you have PM.
burmagirl
- Z Register member
Oodles of posts on here about leaky roofs. Search for hints and tips.
Best
C
Best
C
smartypants wrote:Conor?
With an M??
The World's gone mad
- Contact:
hi
There is adjustment to the roof
undo the allenscrew and turn the roof
catch one turn that normally does he trick
Ray
Ray
I don't have a picture of what I did to stop the leaks, but it really is as simple as cutting thick bits of rubber the shape of the hood frame, and glueing/bonding them in between the folds in the roof (where the nasty water comes in!)
I can't take a picture of it for you, as I have my hardtop on the car now, and of course you have to remove the bits of rubber for the hardtop to be fitted. But once its not hardtop weather, they will be back on again!
Suzy
- Tourniquet
Pansy ?? No, not me.. its just I don't like having the roof down in the rain... and as thats pretty much all we are getting lately, I thought I would keep it on..
Its just been into the garage to be sprayed the correct colour, and as it looks soooo sexy, I have decided to keep it on even though its not that cold yet..
Before
http://i97.photobucket.com/albums/l211/ ... C00631.jpg
After
http://i97.photobucket.com/albums/l211/ ... 006157.jpg
http://i97.photobucket.com/albums/l211/ ... 006160.jpg
Before
After
Suzy
Soft top down in the rain is great fun provided you go fast enough to ensure the rain passes overhead . Not much fun if you have to stop at lights though
Another cure for a leaking roof is to adjust the stop on the window mechanism. Bit tricky to get to as its a small adjuster inside the door body but worked for me.
Daverave.. you like sitting in your car with the roof down when its pissing down? Hmm.. I would like to see it...
Most people who take the mickey out of roof down roof up hard top on hard top off, are the ones who can't afford a hardtop..
Why is there such a thing about roof up roof down, and having hardtops!? Its our own personal choice, no one elses.
Suzy
Not taking the Mickey. Have no problem with roof up, down, hard or soft just drive mine for fun so prefer to drive it with the roof down whenever I can. If I think its going to rain too much the baby stays tucked up in the garage!
BTW think you did the right thing changing the colour of the hard top. The guiness look just didn't look right.
