Wheels
- Justin Time
I just had 8x18's added all-round, and the fronts are slightly proud of the farings. I haven't measured them yet but they look to be a couple of mm outside of the arches. Not majorly noticeable, but this will no doubt increase if you add the size you mention.
I am running the BBS 19" Motorsport Wheels (designed for the Z3M) on my ///M with 8.5J front and 10J rear. I have used spacers at the front due to wanting to widen the track and put 245's on the front and the tyres do protrude but still legal. My suspension setup (KW Variant 3) has been set well so I do not get impact on the arches at the front. On the rear I have 285's and which are as wide as I can go without issue inside the wheel arch but still have spare space on the outside edge.
Not sure what the offsets are but they are standard BMW for the Z3 M.
Hope that helps.
Hope that helps.
Now with both the 411 bhp Supercharged Z3MR and a WRX STi Wagon getting a 3.4 litre transplant and an XKR with mods planned.
Fast is good, faster is better. Wheeeeee !!!
- cowboybebop
Re: Wheels
With those offsets you know your wheels are going to protrude 19mm (3/4inch) more than your standard 7.5 wheels on the front so it depends if you ae happy with that. Gazza had 8.5s on the front of his 2.8 with an offset of 38 so they protruded 16mm above the originals. I saw that car at Gaydon and although they did stick out slightly they looked fine to me.F99ANT wrote:Does any one have 8.5 x18's et35 on the front of their Zed looking at a staggered set up 8.5 front and 9.5 rear i know the rears are ok just worried the fronts may stick out a little any one help??
Dav the wheel nut
Re: Wheels
Thats what i'd found i'm not sure if it's a little to much like the dish on the rims though think the staggered set up will fit the car well, the seller advises they fit no problems on a Zed but as i will be lowering it also on a set of coilovers the clearance needs to be looked in to wheels are here...Dav wrote:
what do you think???
- cowboybebop
- topfuelking
I run 8.5x18 et 47 on the front and 9.5x19 et 32 on the rears and the fit is just right
THANKS MARC
SYMPTOMS OF A BOOST JUNKY
Re: Wheels
I'm sure if you ask the current owner Cosmosblack very nicely she may take and post a few pics from the front of the car so you can see how far the wheels protrude.Dav wrote: Gazza had 8.5s on the front of his 2.8 with an offset of 38 so they protruded 16mm above the originals. I saw that car at Gaydon and although they did stick out slightly they looked fine to me.
I thought the wheels were 8 x 18 et 38, can't be sure though
- topfuelking
i have no rubbing or touching budDav wrote:Are you running 18s or 19s?both.. 18s front evo copys and 19s rears genuine bmw e46 m3 evo with 5mm off the offsettopfuelking wrote:I run 8.5x18 et 47 on the front and 9.5x19 et 32 on the rears and the fit is just right
Do you have any problems with the fronts touching the suspension with those offsets?
THANKS MARC
topfuelking, looking at the shading on the pic of your car it looks like you have a two tone bonnet, Arctic Silver/Sterling Grey
Breyton Spirit
Hi just put on 18x8.5 Breyton Spirit's with a 38 mm offset. Wheels are fantastic and pictures don't do them justice. The back are fine but the front tend to stick out a little. Certainly not a problem but I definately wouldn't go with any less offset than 38mm. Tend to kick up a few stones.
How to post pictures..........Camper wrote:Sorry for the stupid question but why does my picture not show up like the others? You have to download it. Any tips. Thanks
http://www.zroadster.net/forum/viewtopic.php?t=7658
- topfuelking
garythefish wrote:topfuelking, looking at the shading on the pic of your car it looks like you have a two tone bonnet, Arctic Silver/Sterling Grey
yes it is bud
THANKS MARC
