How to I clean the cam position sensor? (1998 2.8)
I've been struggling with a few hesitant starting issues recently and some low power problems. I've also had some momentary loss of power (see a thread with that title for more information). Many posts on here refer to the inlet cam sensor; the car is a 1998 2.8 - single Vanos.
I've had the OBC read and there are no fault codes, but this poor starting is happing every day now so I need to do something about it.
How do I remove and clean/replace this cam sensor? I'm a bit stumped when I look under the bonnet of this car - I can't really see anything I recognise (no HT leads, coil, plugs etc...). I've had a look at the front of the engine for this sensor but can't see anything obvious.
If there is a guide somewhere or if somebody could post a photo, I would very much appreciate it. What do I need to remove to get at this thing?
Many thanks,
David
Many thanks,
David
This post may help. Am still looking for a piccy - there will be one on here somewhere. Unfortunately searching for "camshaft sensor" comes back with a gazillion posts as it one of the most common problems on the zed.
Cam Sensor
It's underneath the VANOS solenoid, whihc must be removed, along with the oil suply pipe. Then it's easy - just pull it out and wipe away any sludge around the tip.
I tried to do this this morning, but unfortunately didn't have a big enough spanner - I need a 32mm open ender for the VANOS solenoid.
However, in searching for that information, I came across the following link:
http://danzee.org/cars/Cam_Sensor/M52_I ... ment.html
I shall go out and buy the necessary tools (and some unnecessary stuff in the January sales) and report back!
