H.iiiiiiii......ddddddddd
hey guys how u all doing
my mate just came back from hk yesterday and bought me back as i requested a HID kit Lovley stuff ehhhh....
I have spent about 1 hour fitting this kit on this sunny sunday morning effects in the day arent all day now im waiting for night fall to come and try em out
I also asked him to get me some LED side lights spen 5 minutes installing them but big dissapointment when i relised one side was dead
But on the good hand at least i got the hid installed
dohhhhhhhh.............
HID's are installed but i have one problem everytime i switch the damn thing on my instrument cluster looses power andd resets all the inspection lights come on
does anyone know why and how i can fix this problem ??
In fact, the HID design must be a bit duff if it's causing such a problem = are the unit's 'E' marked - if not, they have not been tested and are illegal to fit in any case. I would refer to the manufacturer with the fault before trying any mods. If they are not 'E' marked, tested and need fiddling, get your money back.
Do the HIDs work if tyou just wire them to the battery straight rather than through the original car wiring?
If they do, I think you just need to wire them up via a direct feed from the battery, via a fuse (obviously) and a relay.
Should not be a problem if they work directly of fthe battery as this will prove they are actually ok and not faulty.
D
D
