sticky electric windows
Roo
Post by Roo »
Hi, I'm looking for some advice. I recently bought an M Roadster and have noticed that the electric windows are "stiff", i.e. they are very slow to move from fully up. I'm wondering if this is a common fault on the Z3? and maybe they need lubrication?
Has anyone else had this problem and, if so, what's the best way to resolve it?
Post by swamper »
you just hit the nail on the head Roo...door cards off and re-grease the runners ..
DC
Post by DC »
As swamper says, it's easier than it looks, just a bit fiddly.
I think there are a few posts about it.
One that helped me:-
http://www.unofficialbmw.com/e36/interi ... panel.html
You don't need a special tool for removing the panels, just something thin and wide between the panel and door frame near the clips, a piece of cloth or thin plastic will protect the door paint.
Dave.
Ian_C
Post by Ian_C »
Check out my guide in the Knowledgebase.
Current...1998 ///M Coupe
Previously...1997 Z3 2.8
Post by Del »
Hi Roo
This seems to be a common issue from forums I have seen online. I acquired my Z3 this Spring and the driver's window was very stiff and seemed to be struggling. You can carefully remove the door card and inner lining with a little patience/care and no special tools - apart from torx on screw behind the side mirror control. I thoroughly greased the mechanism and found that silicone spray (not WD40) worked very well on the vertical side runners. This window now runs more smoothly than the passenger side which I previously thought worked fine!
Post by Jamezee »
The silicone spray sorted mine out :thumb:
Roo
Post by Roo »
Thanks guys, much appreciated - a job for the weekend
