I'm going to do some servicing on my Zed soon, including replacing the brake fluid and I'm thinking of getting an Gunson Eezibleed Kit. Has anyone used one on their Zed? Any tips and tricks I should be aware of?
Also how much fluid should I buy?
Thanks for your help
Dave
Re: Gunson Eezibleed Kit
Brilliant piece of kit and do easy to use. You need a wheel to act as the pressure reservoir so unless you have a compressor or second vehicle a 12v compressor is also required.
1 litre of fluid should more than enough.
Sent from m'iPhone using TappetTorque
I bled my brakes earlier in the year using one of these, must say real easy and hassle free! well worth £20 from screwfix. I bought a 750ml bottle from eurocarparts and still have a bit left. Total time, about 1 hour. recommended
Thanks for the prompt reply Titan - I'll get oneTitan wrote:Brilliant piece of kit and do easy to use. You need a wheel to act as the pressure reservoir so unless you have a compressor or second vehicle a 12v compressor is also required - 1 litre of fluid should more than enough.
There's currently one on Amazon for £15 - I'll get one.pedro20001 wrote: well worth £20 from screwfix.
Mike Fishwick has recommended it on previous forum threads. It uses pressure bleeding which the Haynes manual says is the only method specified/approved by BMW. Haynes says that the pressure should be below 29 PSI to avoid reservoir damage.
Thanks Del, an excellent article from Mike - very useful
