Went to change the oil today (for the 1st time since I've had the car) thinking it'd be a breeze and found the following issues:
Drain plug will be a major pita to reach (2.8 M52)
I can't fit anything under the car to catch the old oil !
Basically the front end is too low for any of my usual oil-catching devices...Can anyone give me any suggestions on what you are using for the job ?
With this issue and the fact that I'd need 3ft long arms to remove the drain plug it looks to me like a job for a ramp.
Oil change - car too low ?
Visit my Progress Thread - http://zroadster.net/forum/viewtopic.php?f=32&t=35276
Re: Oil change - car too low ?
Drove mine on to a couple of short planks just to raise it those vital extra few inches.Used a jack to raise side where sump plug is to loosen then lowered whilst draining.
All much simpler than I anticipated and will be doing all my own oil changes from now on.It is also worth changing the 2 small o rings when doing the filter as again very easy & cheap.
Gareth
Gareth
I use one of these (Pela 6000). Some people aren’t keen on these vacuum pumps but personally I find it brilliant. It’s essential to do it when the oil is nice and hot so that it flows freely and any sludge is melted and mixed in. It is so easy that it’s a breeze to change the oil more frequently and so care for the engine even more. For those wondering whether it gets all the old oil out, all I can say is that I changed mine by this method last November and the oil on the dispstick still looks like honey.
http://www.pelapumps.co.uk/
I use an old cat litter tray to drain the oil into, raise drivers side to undo drain plug then drop it back down again to drain.
Luckily my neighbour has a car lift (used to rally a Morgan) so I used that
Thanks for all the advice guys !
Don't forget to remove the filler plug before you remove the drain plug, just in case you cannot unscrew the filler plug and are left with an empty sump with no means to put new oil in! I ended up using a breaker bar to undo my plugs they were so tight!
Bonzo.
Bonzo.
Buy a decent trolley jack for about £35 in Halfords. Two of them are even more useful for various jobs.
- Badman gee
I changed gearbox oil with small stands!
A lot harder than the engine oil!
Hard gearbox oil? How did you get it out of the drain hole? Hmm......
