I changed the rheostat light a year ago, and now it's gone again....there are some "tricks" to help that little light live a little longer? something like more or less watt, or other tricks...
air grille rheostat lamp frequent blowing
Re: air grille rheostat lamp frequent blowing
Didn't know there was a light here!!
It is illuminated all time the ignition is on, which is why it is one of the first bulbs to go. An LED would be good for this, but it would need to be a warm colour to match the rest of the lighting. It might be possible to cannibalise an old bulb to make an LED fitment if there isn't a direct off-the-shelf replacement.
Same! Is it easy to access with the under dash trim removed?Pierrick wrote:Didn't know there was a light here!!
1997 2.8 Z3 | Gallery Thread
Search for nephew hole, and you will find the answerXVar wrote:Same! Is it easy to access with the under dash trim removed?Pierrick wrote:Didn't know there was a light here!!
I really wasn't sure what I was going to find when I searched for that but sure enough, it found the thread Cheers Brian!
Here it is for anyone else who's looking for the guide on removing the headlight switch/lamp: http://www.zroadster.net/forum/viewtopi ... =5&t=20601
