oval mirror
oval mirror
can you see what it is yet
"Shmear Shmoo Shmirror?"
(Edited: to keep everyone else guessing.......)
Re: can you see what it is yet
doh that was too quick was hoping I could keep it going for a while
Sorry... I'll edit my comment, so others don't guess
yeh cool. just checked the post - 8min
Jacuzzi to go in place of the boot lid?
m style interior mirror.. or a tissue box...
hey Jacuzzi would be great, though a bit rear heavy, unless I pump the water from the rad then back again after I finished. ummm will have to find some scented antifreeze or something. personally I thought it looked more like a sub box of some kind.
Where's the periscope then?
hadn't got around to that bit yet.
the drawing will be divided into 25 planes, each one is printed onto paper, cut out and stuck onto 1mm flexi Perspex, these are then cut and stacked back up again. the steps from each plane are filled with modelling clay and finished smooth. this forms the plug for the mould. the plug is then cast in a kind of liquid plastic, this stuff is great for moulds or you can even use silicon.
the old one (still not mentioning what it is) is simply popped off its ball and the new one popped back on again. simple
I have looked everywhere for one but cant find one that is a simple swap, so im going to make them and put them on ebay I may even colour code some
my composites arrived today, will be building the plug this weekend hopefully
It's the mould for the connecting arm which will attach to the smaller mirror....as well as attach to the OEM clip on the windscreen....
Re: oval mirror
ok folks, I need other peoples opinions please - the eventual mirror will be cast from clear resin with a black pigment, then polished to a glass like Finnish, the other option is to carbon skin it, but would that make it look cheap or aftermarket
Re: oval mirror
..... well done ! I think some Rustoleum matt black paint will give it the right finish.... What are you doing about the internal space for the electronics from the OEM mirrors???
Re: oval mirror
Gut feeling is the carbon might make it look cheap - just my opinion, I am sure there is probably someone on here who can offer images of both finishes?
Re: oval mirror
don't think there is any electronics in mine, the mirror is attached to the window, if there were electronics in mine where is the power supply? I could be wrong. last week I pulled mine off the mount and took it into the house, car still locked ok maybe some don't have this feature. this is a replacement for the rear view on the 1.9. I looked everywhere for an oval mirror I could just swap for the oem square mirror, couldn't find one anywhere so I decided to make my own. am I missing something maybe I will also be loosing the silly dip tag on the bottom, could never see the point in these as if you try to use them the mirror moves. abit like the gear knob showing me the gears, I drive it everyday so why would I need to know where each gear isSouthernboy wrote:..... well done ! I think some Rustoleum matt black paint will give it the right finish.... What are you doing about the internal space for the electronics from the OEM mirrors???
my gut feeling on the carbon finish was the same, at first I was just going to have a black like glass fininsh, however now I have painted the part I will be taking the mould from im not so sure. the colour of this part is very close to my plastic trim and would look more original.
Re: oval mirror
The power supply comes down from the top of the windscreen trim. It includes the sensor/receiver for the central locking which is in the form of a pc board. The wiring enters the mirror via a small opening at the top of the arm just in front of the area where it attaches to the windscreen...
Re: oval mirror
umm mine doest have this. are all z supposed to have this?
Re: oval mirror
Hi.
On the z3forum.nl in Holland the have changed the rear vieuwmirror and made a howto for it.
The used a Cosmic blindspot mirror and it will fit all the electronics needed.
Re: oval mirror
I suppose if someone wanted one with an internal space it wouldn't be a problem either, however I would need to know how large this space needs to be
Re: oval mirror
I see that....perhaps your car model has a different system for some reason...quite peculiar !.... All the Z3's I know of have a small pop out window on the top bend of the connecting arm which allows the power for the pc board to enter there....Anyhow, your endeavours will need re-thinking to accommodate the electrics in other cars one way or the other.
Re: oval mirror
how odd, is mine non original I wonder, maybe mine was a stolen car making the mirror hollow isn't a problem, where is the board located, is it actually inside the mirror casing?
Re: oval mirror
Perhaps you can ask someone to loan you their OEM mirror so you can examine the internals, and the method of access for the wires. There is a connector housed in the OEM arm so that when removing the OEM or M mirror, it is easy to pop the window, and disconnect them before removing the mirror. If it's going to be a problem, perhaps you should run a test where the reciver / pc board is housed inside the windscreen upper trim. If this performs satisfactorily, and it isn't absolutely required to be inside the mirror, then that may prove the simplest solution to your creative effort for a smaller and higher placed mirror. Also, I would imagine a curved smaller mirror would be desirable to maintain the width of view with a smaller mirror ???
Re: oval mirror
Yes...it's housed behing the mirror glass. One has to remove the front / glass section of the OEM mirror to get to it.
Re: oval mirror
If you take a look at my thread there are some photos that show the inside of both the standard and the ///M mirror from when I swapped mine. The plastic rim on the front prises off allowing the glass to come out exposing the circuit behind which is held in situ by two plastic lugs from memory.
http://www.zroadster.net/forum/viewtopi ... 32&t=34180
Re: oval mirror
cheers for the link, the question now dominating my every waking moment is why is mine different
Re: oval mirror
panic over, I have found another z mirror the same as mine phew
http://www.midlandbm.com/catalog/bmw-z3 ... nuu3cj1dk2
Re: oval mirror
ok blond moment over, I don't have remote central locking I don't even have a button on the key for it (just a light button) I have a brick fob for the alarm but no remote for the central locking looks like I will be the only one with the new fangled mirror not that this matters as it was originally for me anyhow. once done I may have a go at a hollow one if anyone wants one.
Re: oval mirror
Just had a look at mine (1998 2.8) and same as wee fellers, no wires but I do have remote central locking?
Re: oval mirror
curiouser and curioser...maybe you had an "aftermarket" central locking system installed Mark..?? Do you both have the same model car ?
Re: oval mirror
no mine is an m44 1.9, but it is 1998
Re: oval mirror
my baby is also an m44 1.9 1998 build and she don't have any electrics in the mirror either or any remote central locking
Re: oval mirror
umm seems to be a 98 thing, anyone got a different year without electrics?
Re: oval mirror
Where is the receiver for the housebrick type alarm? If it is not in the mirror, then there's your answer - the later alarm receiver IS in the mirror.
Re: oval mirror
well that clears that up don't know where the receiver is, I don't actually use my alarm.
Re: oval mirror
That remote is for the alarm and the central locking. They work together.littlefeller wrote: I have a brick fob for the alarm but no remote for the central locking
Re: oval mirror
looks very neat !! well done....you really should've shortened the arm though so that it lifts the mirror higher...even 25mm would be good....In fact a shorter arm would be a winner on it's own !!
Re: oval mirror
the mount cup I used does come with a shorter mount, about half the lengh of the original, I did drive it to the shops with no mirror this morning, I think your correct as it really makes a difference with no mirror so a higher one would be good. if you wanted just to move the square mirror up then I can confirm this type of mount fits the mirror great, so if anyone wants to know which mount it is I can point you in the right direction im using the original mount at the moment. I don't know if the ball on the central locking type mirror is the same though
Re: oval mirror
This mirror is very M style which gives a little more visibility in the forward viewing than the original - especially around the left hand turns. In addition to this I have found an addition aid is to get the seat modification that lifts the front of the seat up. I got mine from BIMMERDIFFS but I have since heard that Barry does one too...?
Anyway, the additional extra 2-3 inch of lifting the seat allows you (me at least) to see over the top of the mirror when turning left which is better than the viewing you get with the standard Z3 RVM with which most left hand turns are done with fingers crossed
Re: oval mirror
I had a similar prob as littlefeller I aint the user name - its a long story. but not now I have a much better view. to be honest I hadn't realy noticed it till I was sat at some temporary lights and couldn't see them, since then I keep noticing how much room rear views take up, not just in the zed.
Re: oval mirror
the inches countlittlefeller wrote:I had a similar prob as littlefeller I aint the user name - its a long story. but not now I have a much better view. to be honest I hadn't realy noticed it till I was sat at some temporary lights and couldn't see them, since then I keep noticing how much room rear views take up, not just in the zed.
Re: oval mirror
I'll have 10 sets of seat lift kits next month...
If you search my original post on this you will read that these were developed over some time with the intent of producing an item which would be as safe to use as the OEM seat bolting system, which they are. Also, they don't require any alteration to the OEM set-up of your car. ie. you can remove them and replace the OEM nuts and that's all that is required to restore to OEM.
As you see in the pic below, the spacer has a nipple on one face and a round slot on the other. This allows the spacer to locate the nipple into the floor recess where the seat slide used to locate with it's nipple, and the seat nipple will now locate into the slot... The bolt is internally threaded, and is commonly called a sex bolt.... It passes through the center of the spacer and locks onto the OEM front stud. The height of the lift is such that it will still allow 99% of the backrest adjustment of it's tilt function with taller people, and 100% for others. The benefits are the raised front edge of te seat is just comfortably sufficient to restrict forward slip of your butt on the leather seats under braking. It also gives the impression of being more of a "bucket" seat to the non sport or M seat version. The entire item is made of high tensile steel which was specified for safety. It is essentially as near as dammit to stainless, so rust isn't a major issue.
The cost per set of 2 (for one seat) will be £. 22.00 excl. postage. Last time I posted these the cost of postage was £.14.00 per set. Mostly because the weight and the fact that I can't pop them into an envelope. They have to be packed in a box.
There are cheaper ideas and options one can use, but there isn't another option which is as safe as OEM.
Apology for hijacking the thread...but someone mentioned my seatlift kits....
