Saturday's mystery part
siwilson
Post by siwilson » Sat 04 Oct, 2014 12:58
Who can tell me what this is for?
Only clue is that it's bigger than it looks ;)
No prizes other than props for your Z3 Geekness :)
tags
Re: Saturday's mystery part
Post by tags » Sat 04 Oct, 2014 13:05
The nut that screws down the battery cover. You should have attaching one.
Tags
siwilson
Post by siwilson » Sat 04 Oct, 2014 13:07
tags wrote:The nut that screws down the battery cover. You should have attaching one.
Tags
Nope, it's bigger than that :)
Post by Southernboy » Sat 04 Oct, 2014 13:20
It's called a nut, and is generally used to secure items where a stud or a bolt forms the reciprocal half.... I would have thought you knew what a nut is....... :D
siwilson
Post by siwilson » Sat 04 Oct, 2014 13:27
Southernboy wrote:It's called a nut, and is generally used to secure items where a stud or a bolt forms the reciprocal half.... I would have thought you knew what a nut is....... :D
I didn't ask what it was, I asked what it was for :-P .
Post by Southernboy » Sat 04 Oct, 2014 13:29
.....HENCE MY OFFERING THAT IT IS FOR SECURING THINGS BY BEING FITTED TO A STUD OR BOLT...THAT'S WHAT IT'S FOR....... :roflmao: :roflmao: :cheers
Post by Southernboy » Sat 04 Oct, 2014 13:32
OK....... It looks like the nut which secures the lower end of the rear shock to the trailing arm... and because it's so clean, I might hazard that it isn't located in the engine bay close to any oily substances.... It may be the nut that got away too...?? :lol:
siwilson
Post by siwilson » Sat 04 Oct, 2014 13:33
Southernboy wrote:.....HENCE MY OFFERING THAT IT IS FOR SECURING THINGS BY BEING FITTED TO A STUD OR BOLT...THAT'S WHAT IT'S FOR....... :roflmao: :roflmao: :cheers
He clearly doesn't know :dunce:
One clue, it requires a socket bigger than 16mm
Post by Southernboy » Sat 04 Oct, 2014 13:37
It's the nut sat on top the right front strut mount for the earth connection..?
siwilson
Post by siwilson » Sat 04 Oct, 2014 16:43
Nope!
Requires a 22mm socket. The thread is M14!
Rafolian
Post by Rafolian » Sat 04 Oct, 2014 17:11
Diff flange to propshaft retaining nut?
DAVE P
Post by DAVE P » Sat 04 Oct, 2014 17:17
Looks like a collar nut from the rear suspension? part number 33331126136
http://www.realoem.com/bmw/showparts.do ... fg=30&hl=8
littlefeller
Post by littlefeller » Sat 04 Oct, 2014 17:17
are you all blind or something, you can clearly see its a table of some description, usually used for eating off. :P
Rafolian
Post by Rafolian » Sat 04 Oct, 2014 17:26
I usually eat off a plate!!!!!
Post by Brian H » Sat 04 Oct, 2014 17:31
Is it one of the two nuts to hold the rear beam on to the car?
akirk
Post by akirk » Sat 04 Oct, 2014 17:45
no idea - never dealt with nuts before!
Which bit of your car is no longer working / is now in the ditch having fallen off?!
Alasdair
corky
Post by corky » Sat 04 Oct, 2014 18:04
Looks like the large nut that holds the steering wheel on :?:
siwilson
Post by siwilson » Sat 04 Oct, 2014 18:26
Brian H wrote:Is it one of the two nuts to hold the rear beam on to the car?
The winner!
Good game, good game!
I removed my butt-strut & body brace and thought it a shame to use the old nuts for the rear beam.. £1.92 each
Si,
motco
Post by motco » Sun 05 Oct, 2014 14:12
corky wrote:Looks like the large nut that holds the steering wheel on :?:
Single most dangerous part on any car? The nut that holds the steering wheel! :P
siwilson
Post by siwilson » Sun 05 Oct, 2014 15:58
But on a Z3 its a bolt :)
Users browsing this forum: Bing [Bot] and 8 guests
