Replacement door actuator
simbathedog
Post by simbathedog »
I am going to replace the drivers door actuator on my 99 Z3 & see that gsf do one for £63 incl., however they list 2 types, one for vehicles with infrared central locking & one for vehicles without. Mine has central locking from either key or the black 3 button key, is that the infrared type???? :?:
Inferno
  Z3 roadster 1.8
Re: Replacement door actuator
Post by Inferno »
most likely yes, ask a stealer if you can!
Post by Southernboy »
.....No, it's not infra red...the key sends a coded signal to the receiver which is housed in the rear view mirror. That signal is coded to your car. If you replace the actuator with another OEM unit, you will need to have it coded to match your key. The after market option is to replace all the actuators including the boot and petrol cap flap locks.
Post by Badman gee »
simbathedog
Southernboy wrote:.....No, it's not infra red...the key sends a coded signal to the receiver which is housed in the rear view mirror. That signal is coded to your car. If you replace the actuator with another OEM unit, you will need to have it coded to match your key. The after market option is to replace all the actuators including the boot and petrol cap flap locks.
OMG really? I thought I could just replace the one faulty actuator! :(
I don't think Meyle do electronics - they seem to be more mechanical parts from my experience, but I may be wrong.... suggest try Andy - Spurs Fan here on the forum..he may be able to help you. :wink:
They do, I brought one with 2 years warranty.
.....well...there you go...and Meyle supply quality parts at about 1/2 the cost of OEM...
simbathedog
Now I'm really confused! Are you saying I can just replace the actuator unit that is attached to the drivers door lock or do I have to replace the entire car set :?:
If I can simply replace the one I can get one locally, they have them in stock, it was just the infrared bit that was throwing me.
You only need replace the one unit and have it coded to your key. The coding to the key is quite simple, and takes a minute. I don't recall the seqence of pressing the buttons, holding until the red light fashes etc etc...but a BMW mech will know how to do it -or try googling "replacing BMW Z3 door actuator" - you may find they tell how to match the part to you key code.
......here you go...seems you won't have to code the new actuator... read through this forum post and see what parts you need and the comments made...
http://www.zroadster.net/forum/viewtopi ... =5&t=35521
simbathedog
Got ESF to match to BMW part No. will have one on Monday for £57.00. I used this great article http://www.zroadster.net/forum/viewtopic.php?t=17528 to strip it out. Thank you
