gear stick
murray
gear stick
Post by murray » Mon 25 May, 2015 20:29
Hi, is the gear stick normally pre wired ready for an illuminated type, i have the plastic gear head with no apparent wires,
johnz3
Re: gear stick
Post by johnz3 » Mon 25 May, 2015 20:34
Others will advise for sure but think it might only be the 'sport' models that have the illuminated gear stick.
Re: gear stick
Post by Brian H » Mon 25 May, 2015 21:12
murray wrote:Hi, is the gear stick normally pre wired ready for an illuminated type, i have the plastic gear head with no apparent wires,
The wires should be there, you will have to have a look around to find them, the loom runs down the passenger side of the tunnel.
HTH
Users browsing this forum: Google [Bot] and 1 guest
