missing some thing
missing some thing
Post by peter2b »
got the hard top on today with the help of a mate who pulled the door card off last week end , but when I dropped the drivers window some thing went bonk when I removed the dood card I saw 4 things that didn't look right :?: 1, the membrane was missing 2, the air bag was missing :shock: 3, 3 of the clip brackets had been ripped off 4, under the bottom window guide there was the lift arm that had poped out the guide no 4 was easy to fix , no3 on order from wonderloaf just no 1 and no 2 to sort any one know where I can get them from, also the top widow seal by my right ear there is a small gap about 4 ins long, in that area the rubber feals harder than the rest any help with a part number fir a new seal?
Re: missing some thing
Post by BladeRunner919 »
If the airbag is missing I'd expect the airbag light to be illuminated. Are you sure your car is supposed to have them (and hasn't just been retrofitted with a door car from a car with side airbags)?
Post by peter2b »
don't know I got it last year as a cat c, it had been hit just above off side bumper , there is a bit of cable with the end covered by grey foam near the top hinge hanging loose that looks like it was plugged into some thing
Post by Southernboy »
If you look on the inside of the door card, you should see the mesh panel where an airbag would be fitted. That's the panel which would blow out in the event of an accident. If they are the original door cards, and it doesn't have the panel, it may not have been originally fitted. If you have seen the connector on the steering and passenger airbags, you will know the type of connection fitting required. Perhaps someone who does have a side impact airbag will provide a photograph of the set up to help you ... :wink:
Post by peter2b »
ta I will have a look on the build link to see if it was originally fitted
peter2b wrote:don't know I got it last year as a cat c, it had been hit just above off side bumper , there is a bit of cable with the end covered by grey foam near the top hinge hanging loose that looks like it was plugged into some thing
Probably a speaker cable, unless it's yellow.
Post by peter2b »
it's a black plug with 1 yellow wire and 1 yellow/red stripe , there is only 1 speaker fitted on the drivers door but it looks like there is another piece of mesh over a simular size hole could that be for another speaker?
There is space for two small speakers in the door, but I think only a very few cars have both. Most of us have just one.
Antm72
Post by Antm72 »
I believe only cars fitted with the factory H.K system has all the speakers but as with most bmw models the loom is standard so it may not be missing its more likely not fitted.
Brian4
Post by Brian4 »
Hi Peter, The door airbag connectors are yellow plugs and have white with blue stipe and White with yellow stripe.
The door speakers High range have black plug and yellow/red stripe and yellow/brown stripe. There should be 2 small speakers in the door card top just above the grab handle and behind the mesh.
3.0I Topaz Blue
2000 E36/7 Z3 3.0i
2016 F31 335d
2015 F21 118i
Brian4 wrote:There should be 2 small speakers in the door card top just above the grab handle and behind the mesh.
As mentioned, most cars only have one, unless they have the top of the range stereo fitted, but the wiring is there for both.
Brian4
Post by Brian4 »
Apologies didn't make myself clear I meant 2 speakers one in each door.
3.0I Topaz Blue
2000 E36/7 Z3 3.0i
2016 F31 335d
2015 F21 118i
