2002 2.2 Oil Filter?
Lancsbob
Post by Lancsbob »
Hi All
Am trying to get an oil filter for my 2002 2.2 which includes the "O" rings whenever i find
one on Ebay it says not suitable for 2.2, others only have the large "O" ring & a copper
seal which says its suitable. Being the first time iv'e changed oil not sure which is right.
Can anyone point me in the right direction.
Cheers Bob
Brian4
Re: 2002 2.2 Oil Filter?
Post by Brian4 »
Hi Bob
Eurocarparts list 3 and a branch in Wigan, I usually end getting the Mann filters as we used to use them at work not cars though
http://www.eurocarparts.com/oil-filter
Just checked as it is the same as my 3.0, same M54 engine different bore/stroke. The come with O ring and copper washer.
3.0I Topaz Blue
2000 E36/7 Z3 3.0i
2016 F31 335d
2015 F21 118i
Lancsbob
Post by Lancsbob »
Thanks for that.
RealOEM shows one large o ring & 2 small o rings NOT 1 large & a copper washer.
I can't see any mention of a copper washer. Whats it used for?
Which do i get?
Cheers Bob
mwpe
Post by mwpe »
The copper washer is for the sump drain plug. To get the two small washers you need to find the numbers on realoem and order them from a main dealer.
Post by colb »
My 1.9 filters came with copper sump washer large rubber seal and the two small rubber o rings for the filter housing, have a Hengst Filter E104HD43 and a UFI 2500800 sitting on the garage shelf both with full sets of seals and o rings, the Hengst one came from Europarts.
Looking on Real OEM parts and cross referencing the small o rings it looks like they were fitted to the Z3 range across the model range to June 2002 so if you cant get the o rings using your 2.2 details get a 1.9 filter which includes the o rings. I think you will find the 1.9 filter itself is the same as the 2.2 filter up to June 2002 as well. If you just want to use the o rings then its not a lot of money to get a 1.9 filter and just use what you need from the package. If you do get a 1.9 filter be sure to compare the size against your 2.2 filter just in case there is a size difference before using the 1.9.
2003 BMW 2.5 Z4
Lancsbob
Post by Lancsbob »
Thanks for that.
Iv'e managed to get the 2 "O" rings from Latvia on ebay. Couldn't find anywhere else that has them apart from main dealer.
Why do they only supply 1.9 filters with the 2 o rings & not any others?
Cheers Bob
bentley-boy
Post by bentley-boy »
My Fram filter came with all 'O' rings plus the sump plug copper washer :) Guess it depends on the manufacturer/supplier.
lightning
Post by lightning »
Lancsbob wrote:Thanks for that.
Cheers Bob
Why did you not buy them from the main dealer? I got mine from there and they only cost a few pounds.
Have they put the price up? Land Rover have done that on many Defender parts in the last 12 months. For example a TD5 rev counter old price £85+VAT new price £260+VAT
