As title states, my little Z, has suffered this common fault on the drivers side door card, top section where mirror switches are located.
What is the official fix? mine currently crudely held in place with a cable tie.
Sent from my iPhone
Door card handle separated from door card ( top )
Re: Door card handle separated from door card ( top )
I had the same , I used a hot glue gun to fill in the mess behind the handle where the mounting screw goes when hard i drilled a new hole for the screw , been on now for 3 months still holding(fingers crossed) but I now shut the door by using the lower part of the handle
I suspect this is more down to individual imagination rather than an adopted fix - I like P2b fix, and a glue gun is always handy
I fixed by drilling a small hole in the "meat" of the handle and screwing in a screw with big washer from the opposite side of door card. Also strengthened the area for original screw by putting additional big washers (needed to adjust with dremel to fit in), so that there is bigger area to even the pressure and not so easy to break that handle part.
Also make sure door card is fitted well (replace all broken plastic tabs and fit correctly surround for door opening switch).
So shutting the door without worrying about everything for 3 months now
I repaired mine with a large washer. When I take the door cards out to service the windows I will repair the plastic with Milliput to make a more long lasting repair.
