GPS speedo signal
Zedbedee
GPS speedo signal
Post by Zedbedee »
I'm about to try and fit a Blaupunkt Rome stereo/satnav to my 2000 Z3. It needs a 'speedo signal' has anyone done this before as I'm not sure of the best way to get this. I was wondering if there is a redundant loom for cruise control where I could find a speed signal. Any ideas please?
Re: GPS speedo signal
Post by pingu »
A speed signal comes from the speed sensor on the diff and goes into the back of the instrument cluster.
See p.199 of this...
http://www.porterbility.co.uk/Files/PDF/e36z3_99.pdf
I've used the 1999 version of the wiring diagram because your profile doesn't show the production year.
Zedbedee
Post by Zedbedee »
Thanks for that. My production date is Nov 1999, don't know how much the wiring may have changed, probably not much.
deni2s
Post by deni2s »
I used some wire near steering wheel rack, probably it was white/black (not sure about the color now), but it worked well. I think it was from speedo or onboard computer. If you don't have onboard computer, you should have the wiring for it anyway.
deni2s
Post by deni2s »
Post by pingu »
deni2s wrote:Wiring diagram for your car: http://www.hc.lv/inc/Upload/news_290/File/e36z3_00.pdf
Page 204
Zedbedee
Post by Zedbedee »
Many thanks for taking the trouble to respond, it is much appreciated.
