I know it might be an old chestnut, but there seems to be a lot of conflicting threads on which is the right fluids to use.
I think my car has an LSD so I get the feeling I should be looking Castrol SAF-XJ 75-140 for the Diff, but for the Gearbox I am not so sure. Is it really ATF fluid as some have mentioned or is it an alternative oil. I just need to get it right in my head (and for my Z3!) The Z has done 80k miles. Many thanks
1997 Z3 2.8 Manual Gearbox and Differential Oil Change
1997 BMW Z3 2.8 Roadster
1987 Urquattro
Re: 1997 Z3 2.8 Manual Gearbox and Differential Oil Change
That's the correct oil for the diff with a LSD - but I would check for sure whether you have a LSD otherwise it's 75W-90. For the gearbox there is a lot of debate, confusion and differing opinions made worse by BMW secrecy . It should be a GL4 rated gear oil (not GL5 which has more anti-wear additives). The recommendation has tended to evolve as gear oil technology as evolved to cope with the range of possible temperatures. I've seen single viscosity 75W recommended, 75W-80, 75W-85 and the newest 75W-90. In my own 1.9 gearbox I have Castrol (fully synthetic) 75W-90 GL4.
http://www.ebay.co.uk/itm/Castrol-Syntr ... 1308288981
Unless you have an automatic gearbox, I wouldn't suggest you use ATF in it. ATF is an acronym for Automatic Transmission Fluid. MTF is the acronym for Manual Transmission Fluid - which should tell you WTH you should be using. ( and yes, I refrained from using an F in the last acronym )...
Thanks for the replies, by the way I do know what ATF & MTF mean!
I have read so many threads on here about different oils including putting ATF in the manual gearbox.
I have done this in the past with good results. I run an Audi 80 Sport with ATF for several thousand miles after it initially had a notchy gear change. it seems to do the trick.
1987 Urquattro
