oil pressure light
oil pressure light
3.0i z3 oil pressure light slow to go out in mornings, Have changed o rings and filter but no better ?
Re: oil pressure light
With oil pressure problems I would expect to see it worsen with hot (thinner) oil and at idle revs (flashing light). Assuming your oil is nice and fresh (no old sludge), correct viscosity and the oil filter is working properly (not old, blocked or compressed), my initial guess would be a faulty oil pressure switch. It is quite a simple job for a garage to check oil pressure via the same connection – it may just be case of a faulty switch – on some cars e.g. certain Vauxhalls, faulty switches are quite common. Good makes are something like OE of FAI.
Follow this thread and links through to the end. It may be your problem. Oil squirters towards the pistons was the end result.
http://www.bimmerforums.com/forum/showt ... -Oil-Light
Hope this helps
Muzz
Hope this helps
Muzz
oil light only slow when been stood awhile not at tick over even after a long motorway drive, more like filter draining ?
Is the light slow to go out once you have started the car or when you turn the car off?
when started after stood a hour or more rest of time goes out instantly
I agree with your line of thought. If you have low oil pressure due to engine wear, the light would blink more on a hot engine and typically at tick-over revs. The fact that this is only happening after the car has stood a while when the oil will be cold or cool, doesn’t tend to point to engine wear or faulty oil pump – I haven’t heard of many oil pumps failing on these cars. If oil was failing to get to the upper engine, the hydraulic valves wouldn’t be working properly which would cause problems starting and loud/ticking.Jim Z3 wrote:more like filter draining ?
Like you, I wonder whether oil is slowly leaking back through the “non-return valve” at the back of the oil filter housing. When I replaced the housing gasket on my 1.9, the helpful BMW parts staff recommended replacing the valve and o-ring at the same time, hinting that they sold quite a lot of the complete kit i.e. gasket and valve/spring/o-ring – from memory it was only a few pounds for the 1.9 – the mechanism looks a little different on the 6-pot engine (see link below)
http://forum.e46fanatics.com/showthread.php?t=900804
Thanks Del , Called BMW dealer only comes as a new housing £132.70 + vat , Can't think it can be anything but the non return valve .
