Anyone know the easiest way to remove the doors? Does all the wiring need to be disconnected inside the door itself or can you disconnect it from under the footwell somewhere? It would be easier to access connections inside the footwell I presume and feed them through rather then get it all from out of the door itself but I could do with some guidance before I start stripping everything.
Many thanks
Door Removal
Door Removal
Re: Door Removal
I'm doing this from memory as not near a car and it's been a while since I did it. But no need to touch door internal wiring. There's a single connector in the hinge area. I think it's behind the rubber boot which has 2 nuts holding it down and has to be accessed from the other side of the door.
Getting the door off is actually pretty easy. You'll just have to give the central pin a decent knock when you drift it out.
Re: Door Removal
Thanks, I think I've seen the 2 nuts/bolts your on about but wasn't sure how to get at them as only had a quick look. The rest off the removal looks pretty straight forward although I need to swap the locks over on the drivers door.
Re: Door Removal
Re: Door Removal
Thanks mate, looks straight forward.
