Body parts
Dva99999
Body parts
Post by Dva99999 »
Hi all, been a while since I checked in so I apologise in advance if this topic has been covered but I can't find it. Recently someone hit the front side of my Zed :( . There is a little scratching on the door, kidney grill and lower panel on the drivers side, and a slight scratch on the bonnet. It's more noticeable on the door and lower panel.
I understand I can get a panel from Eurocarparts but can anyone tell me if there is a difference between the widebody parts and the standard body parts.
Does the widebody parts only affect the bumper and rear body panels?
I don't want to order the front lower panel only to find it looks very different.
Thanks in advance.
D
Re: Body parts
Post by BladeRunner919 »
Doors, bonnet and front wings are the same on all cars. You may be better off looking for a second hand part, as they will probably fit better than aftermarket ones. You may even find them in the right colour.
Re: Body parts
Post by bertiejaffa »
Contact spursfaninacoupe - he will have loads of spare panels
Re: Body parts
Post by peter2b »
which kidney pannel do you need as I have a pair left over from my re build one does have a small mark on the bottom chrome bit but untill I dig them out I can't say which one
Dva99999
Re: Body parts
Post by Dva99999 »
Thanks for the replies. It's the driver side kidney panel (right), I've had a decent quote from a friend of a friend to repair and spray the damaged areas but it would be great if I could get parts.
I'll make contact with spursfaninacoupe.
If I could post a pic that would great but unfortunately it says 'board attachment quota
https://www.dropbox.com/s/h62h2ptcd8df5 ... .jpeg?dl=0
I've provided a link if that helps
Thanks again
Re: Body parts
Re the photo issue you need to use an external provider like photobucket
http://zroadster.net/forum/viewtopic.php?f=3&t=7658
Dva99999
Re: Body parts
Post by Dva99999 »
Ive tried using photobucket and it's awkward and very slow. Ive just tried loading some pics on, and although it's showing that I have got 5 pics, I can still only see 1. Then there's the ads!!
That's why I used the Dropbox link as I don't have those above issues.
