Hi, i have just brought some coilovers and im confused on what top mounts i need if any
Do i just go with Meyle or Lemforder or do i need something more suitable for coilovers? or even Powerflex? do i need to change the top mounts or can i use the existing top mounts
Thank you in advance
what top mounts do i need for coilovers
- Contact:
Re: what top mounts do i need for coilovers
Front or rear? What exactly do you mean by coilovers - I assume you mean adjustable springs which are commonly (if incorrectly) referred to as coilovers?
- Contact:
Hi, it's the front Ines and they are adjustable thankyou
You can get a pair of new ones from Euro Car Parts for about £50 so you may as well just replace them if you're going to the trouble of replacing the struts.
- Contact:
ok thank you, i dont mind replacing so thats cheap but i didnt know if they had to be in anything special as i was using coilovers
