Wind deflector to fit AC Schnitzer hoops.
Uncle_Clanger
Post by Uncle_Clanger » Fri 24 Mar, 2017 07:59
I've been given the nod from the other side that a member here is making a perspex wind deflector that will be a custom fit for the ACS chrome roll hoops.
Could anybody point me in the right direction please?
Many thanks
deni2s
Re: Wind deflector to fit AC Schnitzer hoops.
Post by deni2s » Fri 24 Mar, 2017 08:52
I don't think someone does them for sale. You can make your own from template on one of the bottom links here:
https://www.drive2.ru/l/3138409/
Please post the pic of your car with those beauties!
Post by Gazza » Sat 25 Mar, 2017 13:33
I have the plastic deflector designed for the stock roll hoops, I have ACS hoops and the fit isn't good with the deflector.
The template mentioned only has two dimensions so you'll have to figure out the rest.
Post by gookah » Sat 25 Mar, 2017 21:25
Gazza wrote:I have the plastic deflector designed for the stock roll hoops, I have ACS hoops and the fit isn't good with the deflector.
the dimensions only help to order a rectangle of perspex. other than that its of no use
Boosh
Post by Boosh » Sun 26 Mar, 2017 08:35
That's what I did for mine (regular hoops). I knew I'd seen a template somewhere on here, which, after a long search, turned out to not be a great help. So I got a large piece of cardboard and traced my own. The difficult areas were the two slots at the bottom, where the angled hoops bases go through the plane of the screen. I got a sheet of 5mm perspex from a surplus warehouse and started jigsawing. First attempt was a little wide at said areas, so I made another cardboard template and jigsawed another screen, which fits just right. Cutting the slots for the straps required a lot of patience to keep them thin and symmetrical, but all in all, it's a nice little project. After filing the edges (I decided against some black edge trim), it was all done. Took me about 4 hours in all.
A different shape of hoops shouldn't make that much of a difference to the process or cost. It cost me €15/m2 for the perspex (think I've got enough to make another 1 or 2 :wink: ), and €10 for 5m of velcro straps. And you'd be hard pushed to tell it's home made. However, the difference in brightness when the hood is up, compared to the "ladies' tights" OE, is incredible. Glad I did it.
Here it is:
Only very slight drawback is faint reflection of the centre console at night, but not that great a deal, TBH.
Give it a go. You'll wonder how you managed without it!
Boosh.
deni2s
Post by deni2s » Sun 26 Mar, 2017 21:18
gookah wrote:
Gazza wrote: The template mentioned only has two dimensions so you'll have to figure out the rest.
Bullshit. Bring the template to perspex laser cutting service and they will do the rest. Template has all the required shapes. Ask me how I know ;)
deni2s
Post by deni2s » Sun 26 Mar, 2017 21:27
The template mentioned is for ACS hoops with "the rest" already figuered out, not for stock hoops.
Post by gookah » Sun 26 Mar, 2017 21:46
nice language
If you went to the trouble of drawing up a template, it would have been better to put all the dimensions and the radii on it.
That way we could make our own rather than find a laser cutting company.
('_')Z3
Post by ('_')Z3 » Sun 26 Mar, 2017 22:08
In fairness it's my template. I drew it from scratch and developed the shape through measuring an actual one shantybeater sent me when I bought the ac Schnitzer hoops from him. His was a bit rough and ready and i produced a number of prototypes until the shape was suitable. I sent it to deni2 when he requested it after buying some hoops, but i didn't realise he was going to publish it.
deni2s
Post by deni2s » Mon 27 Mar, 2017 09:19
gookah wrote: If you went to the trouble of drawing up a template, it would have been better to put all the dimensions and the radii on it.
Just print it out on paper, attach paper to perspex plate and cut your own. IMHO laser cutting will have better appeal ;)
deni2s
Post by deni2s » Mon 27 Mar, 2017 09:20
('_')Z3 wrote:i didn't realise he was going to publish it.
Sent you pm regarding this. I can unpublish if you wish, just let me know.
Users browsing this forum: Bing [Bot] and 11 guests
