more abs woes
more abs woes
hi over the winter removed sills and wings to deal with any rust problems also fitted new rear shocks, had to turn the car around so could work on one side at a time, on one of the shuffles abs and traction control lights came on, diagnostics told me no electrical signal from o/s and n/s abs sensors also brake light switch suspect. taxed it Monday took out for 60 mile run with some left foot braking hoping use would clear the fault, no such luck, am now halfway through changing both sensors and brake light switch, have stripped the hubs both sensors covered in bits of rust from the back plates, not got around to the brake light switch yet, am waiting for the parts to arrive to finish the job, mind you the front hubs and suspension legs are now as shiny as the new wishbones I fitted last year, every cloud has a silver lining
