Hiya,
I've got a question about the power steering in the Z3. I hope no one takes offence, but is it really as bad as i think it is or is just me?
My first car with power steering was a Rover SD1 3500 back in the 70's, then a load of cars without it, and now my last 4 cars with it. Basically, none of them were as "absent" as the Z3; it's almost as if there's no power steering at all. It was the same with all the potential Z3's i tried before i bought this one.
I always thought that powersteering made things really easy at low speeds and then progressively stiffend up. My experience with the Z3's is the other way round.
Am i daft or is this by design?
Power steering
Power steering
If it ain't broke, don't fix it
Z3 1.9 2000, Cosmos Schwartz
Re: Power steering
Nope, mine's great on my 3.0 Z3
Re: Power steering
Have you checked the fluid level?
try the steering with the engine on, then with it off, there should be a distinct difference.
No difference.... its not working
check tyre pressures too.
Re: Power steering
MIne's fine. The Z doesn't have speed-sensitive power steering as far as I know, but then your SD1 wouldn't have been either, so it doesn't provide more assistance at low speeds. Is your complaint that it's too heavy? If so, the Z3 isn't over-assisted, which many cars are, because it is supposed to have a sporty nature, rather than a floaty manoeuvering-about-town feel.
Re: Power steering
Okay, it must be down to the "sporty" experience. It does work, but it has more of a frog-eyed sprite or Spitfire feel.
I'll get back to you on the SD1.
Re: Power steering
What? Immediate, nimble and precise?Z3crazy wrote:but it has more of a frog-eyed sprite ... feel.
The Z3 power steering is not as assistive at that found on some more modern cars - you can't turn the wheel with your little finger - but believe me, parking the zed is a lot easier than parking the frog.
Re: Power steering
I'm a new z3 owner and also found the steering quite heavy initially. Having now had the car up to a decent speed, the steering weight feels perfect to me, when 'making progress'. That little extra weight feels superb and nicely sporty to me.
