Head light switch fault
Patty
Post by Patty »
I have a fault related to the dual operation of the head light switch. The switch works ok but the function to adjust the light level of the dash board is intermittent and will not now achieve full illumination.
Is it possible to remove the module which the switch is mounted in to get at the potentiometer to test it.
Re: Head light switch fault
Post by colb »
How to remove is in the knowledge base here viewtopic.php?f=18&t=35763
The photographs don't show because of the third party sharing issue with photobucket.
2003 BMW 2.5 Z4
Patty
Post by Patty »
Thanks for that, I'll give that a go now. Let you know how I get on.
Post by peter2b »
I had the same type of thing ended up getting a new switch
peterz3
Dave L2
Post by Dave L2 »
When I stripped that dash out of mine to have the leather repaired, I found a fine white powder :shock: inside the dash below the headlight switch. I suspect this was the Bakelite in the switch breaking down. I also ended up replacing the switch. I did try disassembling it, but I just made things worse.
