Power Hood Problems ........Help..
My Wife's power hood on her M Roadster had developed a intermitent faulty when trying to open and close , sometimes it works fine then it will stop in any position it wants , anyone any ideas where i can start ? i,m pretty handy but wondered if there are any normal faults with these like switch ect , the hood had has alot of use . thanks for any help . Tux
Would it not have been easier just to check to see if the brakelights came on? It's the same switch!
Can't see the part for the wiring set. The replacement microswitch is expensive, so it might be part of it. I would just do a DIY job on it - just cut and replace the offending section with similar gauge wire - use stranded rather than solid core as you want it to bend.
Power hood problems
I had a similar problem with mine last year & it was just a case of take off the motor (in the boot) & put it back on again! Mines worked ever since, it might have been a bit of dirt in the oil.
Good luck
Good luck
