My rear tracking is out. Tows out rather than in.
The chap at the tracking centre said Z3 rears can't be adjusted.
Does anyone know if this is correct?
If so is there a work around?
Rear tracking on an M///
'High G' motoring enthusiast
Re: Rear tracking on an M///
No they can't.
You can get eccentric bushes but you don't get much adjustment.
That or have the rear axle modded with slotted washers which will allow toe or camber and toe correction.
Z3M drift car build --> http://zroadster.net/forum/viewtopic.php?f=6&t=36890
How much toe out Robin? What's the tyre wear like?
A little could just be a worn trailing arm bush, but a lot might indicate a bent trailing arm. They are a 'sacrificial part' in case of a bang.
Some of the kits can be found here
Ireland Engineering
or Here
Trailing Arm Camber Bushes
Option 2 is an easier fit than Option 1 but not sure if the kits have the same amount of adjustment.
HTH
Ireland Engineering
or Here
HTH
Many thanks Brian. I'll order a set of the Ireland Engineering slotted brackets as It needs quite a bit of adjustment.
Robin wrote:My rear tracking is out. Tows out rather than in.
"Tows?"
Does it rhyme with 'cows?'
John Walker
Baarn, Holland
Baarn, Holland
