I have just fitted these into the footwells of my Z3...they are originally from a 3 series E36 and were sun visor lights...they are a really good fit and match the finish in the car nicely. The connector required is identical to the rear HK speaker connectors...only requires the one wire to be re-located to the outer slot to engage the 2 pins on the light fitting...
E36 VISOR LIGHTS
Re: E36 VISOR LIGHTS
Looks good. Wired in to the interior light circuit, I assume?
Yep...wired to the same circuit as is contrlled by the interior switch at the top by the rearview mirror...that way it can be switched on / off as required when needed etc.
