Is someone knows if OEM center caps would fit AC wheels type 3?
Thank you,
C
Center cap / AC vs OEM
Re: Center cap / AC vs OEM
.... NO....
AC are considerably larger... Also, they have a different clip fitting... AC have a sprung steel wire which houses into a groove just inside the rim center hole...
Thank you!
.... don't panic... you can still find them..occaisionally on eBay...
Thank you for the link. But I was looking to fit carbon center caps. I still have my AC. So the real question is; is there any carbon center caps that would fit AC type 3?
Sorry
Sorry
Why not use some carbon sticky on them,,,, that way you can always reverse the process if you want...
They do the metal ones for the type III race wheels but they are c£25 from memory if you can still get them. Otherwise as suggested you would have to carbon wrap them.
