MOTHERS MAG and ALUMINIUM POLISH
Post by Southernboy » Mon 10 Aug, 2015 07:13
I have looked for an aluminium polish during the past weeks which will actually provide a mirror finish to this meta. Some claim to do the job, and fall short of the mark. I then cam across a you tube vid which rated the top 5 aluminium polishes. In the #1 spot was Mothers Mag and aluminium polish. I found a small tub locally for around £9 and decided to try it. The results are nothing less than brilliant. I t doesn't require any hard rubbing to deliver. The one tip which is important is that the buffing happens before the polish dries.
It is touted as being "an all metal polish" in spite of it's name on the tub, although I haven't tried it on other metal surfaces.
If it works as well on chrome and Mag wheels as it does on ally, I would say it's worth the investment.
Users browsing this forum: Bing [Bot] and 1 guest
