Saturday's mystery part
Who can tell me what this is for?
Only clue is that it's bigger than it looks
No prizes other than props for your Z3 Geekness
Re: Saturday's mystery part
The nut that screws down the battery cover. You should have attaching one.
Tags
Tags
Nope, it's bigger than thattags wrote:The nut that screws down the battery cover. You should have attaching one.
Tags
It's called a nut, and is generally used to secure items where a stud or a bolt forms the reciprocal half.... I would have thought you knew what a nut is.......
I didn't ask what it was, I asked what it was for .Southernboy wrote:It's called a nut, and is generally used to secure items where a stud or a bolt forms the reciprocal half.... I would have thought you knew what a nut is.......
.....HENCE MY OFFERING THAT IT IS FOR SECURING THINGS BY BEING FITTED TO A STUD OR BOLT...THAT'S WHAT IT'S FOR.......
OK....... It looks like the nut which secures the lower end of the rear shock to the trailing arm... and because it's so clean, I might hazard that it isn't located in the engine bay close to any oily substances.... It may be the nut that got away too...??
He clearly doesn't knowSouthernboy wrote:.....HENCE MY OFFERING THAT IT IS FOR SECURING THINGS BY BEING FITTED TO A STUD OR BOLT...THAT'S WHAT IT'S FOR.......
One clue, it requires a socket bigger than 16mm
It's the nut sat on top the right front strut mount for the earth connection..?
Nope!
Requires a 22mm socket. The thread is M14!
Diff flange to propshaft retaining nut?
Looks like a collar nut from the rear suspension? part number 33331126136
http://www.realoem.com/bmw/showparts.do ... fg=30&hl=8
are you all blind or something, you can clearly see its a table of some description, usually used for eating off.
I usually eat off a plate!!!!!
Is it one of the two nuts to hold the rear beam on to the car?
no idea - never dealt with nuts before!
Which bit of your car is no longer working / is now in the ditch having fallen off?!
Alasdair
Alasdair
Looks like the large nut that holds the steering wheel on
The winner!Brian H wrote:Is it one of the two nuts to hold the rear beam on to the car?
Good game, good game!
I removed my butt-strut & body brace and thought it a shame to use the old nuts for the rear beam.. £1.92 each
Si,
Single most dangerous part on any car? The nut that holds the steering wheel!corky wrote:Looks like the large nut that holds the steering wheel on
But on a Z3 its a boltmotco wrote:Single most dangerous part on any car? The nut that holds the steering wheel!corky wrote:Looks like the large nut that holds the steering wheel on
