Pics of Z's with Angel Eyes
I'm still undecided on Angel Eyes so could do with some persuasion/input, I like the look of some but need to keep it as OEM as poss, there seems to be a silly amount of different shapes/sizes/colors etc.. Can anyone post pics with specs of their setup?
These look pretty good (random google search)
There also seems to be orange/yellow versions out there which may look more in keeping with the z3 (e.g. E39 angels) but do they look too yellow/orange??
Re: Pics of Z's with Angel Eyes
I've had mine for about six years now, initial cost was about £100
I had to replace one about six months ago, the set of 4 cost £30 on Ebay
From memory they are 6000K.
I think mine are the same £12.50 off ebay because they didn't know how to fit them
Sorry about the pic bloody phone
Si-forks on tapatalk
E30 318 1988 Gone
E36 320 1992 Gone
E36 328 1995 write off
E39 525d M Sport 2003 Current
E37 Z3 M44B1.9 1997 Current
E36 320 1992 Gone
Here you go shanty, had mine from eBay think they were 6000k/7000k. They are the closet to oem I could get at the time they were around £30. But you have to make sure you get specific Z3 ones as they are a different shape. They are fitted in front of the lenses, some do fit them behind though. I prefer them in front. Wired directly into the sidelights so they come on when they are switched on and are visible in daylight.
all the above look good, g8jka have you got any close ups of the headlamps both lights on and off?
Also are these the ones you mean? any preference?
http://www.ebay.co.uk/itm/220957523934? ... 1423.l2649
http://www.ebay.co.uk/itm/270890298158? ... 1423.l2649
These are the only z3 lower rated ones (6300k), i assume 8000k would be brighter and more blue? :
http://www.ebay.co.uk/itm/350478680114? ... 1423.l2649
No havent really got any at the mo and this are the best I can find with the lights off
These were my old lights but the were exactly the same set up as I have now (minus the clear indicators)
The links you have above all look good, the ones from Ireland are the exact shape needed and there are not many sellers that show a picture of the actual angel eyes. Although I would be tempted with the 3rd ones as they are cheapest and from UK, if they are not the correct shape you can send them back as they are listed specifically for Z3 fitment so could be returned if not. Seems to be a few choices on ebay for them but I was always a bit wary if they didnt have a picture of the actual rings as they are a different shape. The place I had mine from no longer sell them but the ones in your 2nd or 3rd link look good. 8000k would be more blue like you say, oem is probably around 4000k but I have never seen them for a Z3 in this colour.
They look a very good fit, thanks for posting pics
I'll drop the seller of the bottom ones a message since they should be a bit closer to OEM colors
Yes the fit is great. although the chrome ring around the lenses have to be covered ever so slightly but they are a worthwhile mod
I was thinking about stripping the chrome paint off the lenses and mounting them behind? do you think they will fit ok that way?
I dont think they are quite big enough to fit exactly behind where the chrome would be if you stripped it. You would have some overlap of lense/chrome part I think which may block or distort the light from the ring. You will be able to see better when you have the rings and put them against the lenses whether they are better behind or in front and some rings differ slightly in size which will depend again on whether they go in front or behind.
Mine fitted in front nicely but others who have brought them had to fit them behind the lense as they were slighlty smaller and wouldnt sit it front.
You will have to wait till you have them and then try all the different locations.
Mine install behind the glass
BMW Aero Side Skirt/rear spoiler & chrome roll bar/ handle
AC schnitzer front/rear bumper splitter,Exhaust,type2 17"
BC coilover/H&R swaybar/wiecher's strut
Would you show one pic without light up the angel eye? So that we can see the different of the angel eye in front of the glass and behind the glass.sobe_on wrote:
Having moved to France, Ive finally got my LHD headlights installed.
- Attachments
- Finally got my LHD Angels installed
- (194.13 KiB) Downloaded 27 times
Hi.
Anyone know what should be the exact diameter of the each ring?
I'm in pursuit of led ones - this is what I can choose:
-whole-circle 106 mm
-whole-circle 125 mm
-whole-circle 127,5 mm
-semi-circle 131,5 mm
-whole-circle 145 mm
-semi-circle 146 mm
-semi-circle 160 mm
They sell 106mm as the ones suitable for z3....
-semi-circle 146 mm
-semi-circle 160 mm
so how come when i posted up asking about angel eyes i got no replies????.......not one!!!
oh well, i've now got all the info i need from this thread
signed:
billy -no-mates
signed:
billy -no-mates
I have a set which go behind the inner lenses and a set that go infront of them, none of which work but I will measure the sizes for you tomorrow. Be nice to see which you go for and how they fit. I want a set again that fit infront of the lenses but I am struggling to find them anywhere now.
I tried using some El wire that can be threaded into the rings when the CCFL tubing is removed but they weren't bright enough and only visible at night.
Do you have any links to the ones you are looking at? I have also seen some led ones but I think they may need cutting down and hopefully this can be done with the led types.
The kits for Zeds will contain different sizes.
From here - http://interlook.pl/product-pol-427-Ring-LED-SMD.html.g8jka wrote:I have a set which go behind the inner lenses and a set that go infront of them, none of which work but I will measure the sizes for you tomorrow. Be nice to see which you go for and how they fit. I want a set again that fit infront of the lenses but I am struggling to find them anywhere now.
But... still question remains about the size... and shape... I'll probably take 106mm full circle and put them in front of the lens... I'll order them this week.
Couple of measurements here
Ones that fit infront of lenses
Larger Ring (Left)
Outer diameter, left to right - 122 mm
Inner diameter, left to right - 107 mm
Outer diameter, top to bottom - 107 mm
Inner diameter, top to bottom - 95 mm
Smaller Ring (Right)
Outer diameter, left to right - 133 mm
Inner diameter, left to right - 118 mm
Outer diameter, top to bottom - 101 mm
Inner diameter, top to bottom - 92 mm
Ones that fit behind the lenses
Larger Ring (Left)
Outer diameter, left to right - 131 mm
Inner diameter, left to right - 115 mm
Outer diameter, top to bottom - 115 mm
Inner diameter, top to bottom - 110 mm
The half circle ones seem to be the same size with both types yet the fuller circle ones are bigger for the ones that sit behind the lenses hence why they won't fit infront and some of the bottom of the headlight needs to be trimmed away with a dremmel.
Hope this helps some people
Larger Ring (Left)
Larger Ring (Left)
I just ordered 4x106mm full circle ones - Led. I'll give an update how it fits and how it looks like.
Total cost - £45. I'm worried that 106mm will be too small... and it will sit in front of the lens...
Maybe they will be a bit small but at least they will fit so its worth a try. Post some pics up when you get them fitted
Still waiting for the delivery. Can anyone tell me at least approximately diameter of the rings in the aftermarket headlights?
That would be very helpful - thanks!!!!
The ones below to be clear
I detangoed and made some PS with the 106mm rings - will recieve them tommorow...
Idk what to think about it... Aren't they to small? I worry about the light beam at night. It will probably gonna be interferenced in a way. Wht do you guys think?
I usually drive z3 before sunset...
Maybe put them behind the lenses...
They do look too small in this pic. Are you sure they should make full circle? I think there was always a gap somewhere...
deni2s wrote:They do look too small in this pic. Are you sure they should make full circle? I think there was always a gap somewhere...
Yeah - ccfl ones. LED suited for zed come only in full ring.
Maybe you are right. In the link above are CCFL angel eyes.
deni2s wrote:Really? http://www.drive2.ru/l/288230376153043075/
Do they fit exactly like above?
I would make a couple of black metal shrouds to sit behind each lens, which blacks out from the edge of the chrome upto the inner edge of the angel eye. I don't know how or if this would affect the beam pattern of light output but it would look as if the lights have projectors in them, with the angel eyes fitted around them.
I know they have kits for the E36 with separates the light output between the standard light and the angel eye so that the rings can still be seen with the headlights on.
Little update - I have recieved bad ones... 106mm semi circle... so tommorow I'll be ordering again from different place. This time also 106mm but - 120SMDs - the ones I was about to get were 66smd... They say that this 120ones look better and are much brighter... at night to bright
ok job done - took me 7 hours. Taking apart, mounting, testing drilling, cleaning, testing, mounting... finished in the middle of the night. But - it was worth it . I tried behind and in front of the lens... behing more oem... but definetly it looks cleaner in front... and it is much easier to mount in front Hope you like it. It is clearly visible at day. Very bright. I have installed a led dimmer with remote so I can tur it off from the car, change brightness, etc etc .
They look great
Any close ups of them with the lights turned off?
@sviru could you do a photo from the front on. Im curious and tempted to buy a set. What made you fit them in front of the lense?
Lee
Lee
bump this post for reference
